Results 21 to 30 of 38
Thread: Pessimistic Fuel Guage??
  1. #21
    Feb 2008
    Quote Originally Posted by Bumpknuck View Post
    isn't running it that low not too great for the fuel injection system?
    ..just something i have heard, not sure if its applicable to our Pogos tho
    Its definatly not good for fuel pumps. The fuel pump is lubricated by the fuel, so if the tank nearly runs dry, and you do this alot, you can kill your fuel pump. Do a dry bench test of an electric fuel pump, and see what happens.
    Also, it has the ability do suck up the unwanted detritis that can exixt in the pick up point in your fuel tank, and then clog your fuel filter. this is alot cheaper to replace than a fuel pump, but an annoyance none the less.
  2. #22
    Dec 2006
    Gold Coast
    Quote Originally Posted by T Go View Post
    Is that even possible?????
    This explains a lot ..... you must have a V8 in there Kai .... only way you can ever beat another V8 .....
    So, the secret to refuelling a V8 then .... switch it off when you fill up .... otherwise you'll never get it full ..... it consumes more at idle than what the pump can provide ....
    Quote Originally Posted by Cygnus View Post
    Looks like you got ripped off by the petrol station!
    It was bone dry when i filled it up.
    There is a little button in the fuel cap. No idea what it is. Everyone says not to press it. It lets some gas out. And then lets you put more fuel in. Someone said its an expansion tank or somthing?? Whatever it is. I press it. And it lets me put another 2L in. Then i press it again and put another 1.9L in then press it again and put another 1.5L in...
    so on and so on...
    I have the receipt. As i keep them all. So i dont mind going through all 10000000 of them to find it
    Oh and in regards to the servo ripping you off thing. Just recently i put 25L into a 20L jerry can. They told me my jerry can holds more then it says. YEAH RIGHT!
  3. #23
    Mar 2008
    Canning Vale, WA
    Quote Originally Posted by Kai View Post
    so on and so on...
    Dont press that button 2 many times... could be like the Reebok Pumps... one more press and the shoe explodes!! Messy when its a Polo tho... haha.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
  4. #24
    Nov 2008
    Quote Originally Posted by Roodosutaa View Post
    I consistently get 5.6 litres into a 5 litre can at every servo I've used even if you allow for a bit of expansion space in the can.
    The can is probably legally allowed to be filled with 5 litres of fuel only. The rest of the space is to allow for expansion.
    I have 20 litre jerry can. I always fill it with 20 litres and no more and there's at least 3 inches of space above the fuel.
  5. #25
    Nov 2008
    Wembley, WA
    Yeah I was gonna ask that too. I did that a couple of times in my previous car, a subi, and my mechanic reckond you can do all sorts of damage. The fuel pump doesn't like it and he said something about damaging the catalytic converteras well. Beats the hell out of me how it can damage it though. I only ever did it twice and the car was still going strong after 17 years of pretty rough abuse.
  6. #26
    Feb 2008
    Quote Originally Posted by mozzzy_2000 View Post
    Quote Originally Posted by Blitzen View Post
    I have no idea how it could damage a Cat Converter, but I have destroyed a fuel pump doing a dry bench test just to see what running a fuel tank dry can do.
  7. #27
    Nov 2008
    Wembley, WA
    I think, as it was mentioned, debri can perhaps get through the exhaust and clog up the catylst perhaps? I think thats what my mechanic told me.
    But yeah running out of fuel serves too purposes; You'll never do it twice and you'll find out the maximum capacity of your tank! No more guessing next time.
  8. #28
    Jan 2008
    Lets get one thing clear people!
    Running low on fuel does not mean your fuel pump sucks dirt from the bottom of the tank. I dont know if any of you have ever pulled out an in-tank fuel pump out, I have, if you have a look at it, the pump always draws fuel from the bottom of the tank. Its the only way your car can use that very last liter of fuel before the engine stops.
    The fuel that goes in your car is generally quite clean and any dirt that may get in the fuel tank will be trapped in the fuel filter. The only dirt that may get to the combustion chamber would be microscopic. And once the spark fires it would be disintegrated due to the high temperature.
  9. #29
    Nov 2006
    My light doesn't come on till 30-40km. Closest I've filled to 45L is 42 and I had been cruising on 0km for some time. I almost always fill mine at 10km to empty.
    Is it perhaps something about chipped cars that there light comes on earlier? I haven't read the full thread.
    aus liebe zum automobil
  10. #30
    Feb 2008
    Quote Originally Posted by Bubu View Post
    Thats generally true, however I have removed an in tank pump from a car with a plastic tank(an EL Falcon) to find ou why the pump had failed, and found a piece of rusty metal about 1.5mm accross that has lodged in the pump.
    A cool little experiment to do on a fuel filter(and just about any filter) is to cut or pull out the casing, and then cut out a section of the filter element. You then squeeze this element in a vice to get all of the fluid out, then remove it and open like an accordion. In doing this you can see what you filter has been catching, and it is also good for fault finding and componant failure analysis.
