Looking at ordering bits in now to fit early next year.
Looking for info on the 2.0TSI coils .... ECS part #?
Where can I get performance rods? ECS only has for AWD, where we get that for AWP normally?
Clutch kit this stg1 Volkswagen Golf IV 1.8T > Drivetrain > Clutch > ES#125 Stage 1 Clutch Kit - Steel Flywheel (14lbs.) - ESR198031S1 suitable for 200wkw? or Stg2 Volkswagen Golf IV 1.8T > Drivetrain > Clutch > ES#126 Stage 2 Clutch Kit - Steel Flywheel (14lbs.) - ESR198031S2SF
Also, Polo's have 113 or 114mm ring gear?
When I think of more things, I'll ask
I'd get the stage 2 if you thing you'll be making that power, otherwise do a stage 1. I'll be doing a stage 1 and if I waste that, Stage 2. I don't mind pulling the box off twice if I have to. If you aren't doing it yourself and paying for labour, then consider that cost too.
INA do rods, loads of places you can get them from. About $400 plus bearings and shipping seems to be the norm. Get the bearings at the same time, whatever is recommended by the folk you buy the rods from.
I think that's the big question on the ring gear, you don't know until it's apart. If you are looking at Wavetrac, don't do Redline oil.
