Originally Posted by
VWindahouse
I thought I would give Superpro's Polyurethane anti-lift rear control arm bushes a go and the results are brilliant
Now there is hardly any lose of traction or hesitation and it just powers up the hill even though you can feel the chassis lifting.
Yes, the anti-lift part of the name is rather misleading as it is really anti-anti-dive (which also results in less anti-lift) which increases the vertical compliance in these cases giving increased mechanical grip (grip under heavy braking should also be marginally improved). The added castor negates the possible tendency to scrub the front tyres when turning in these situations.
Thanks for the feedback re NVH - my worry about this was the reason I went for the SEAT solid rear LCA bushes instead but it looks like I have missed out on a good thing
It will be interesting to see how they hold up over a few thousand km (the split design should help a lot vs a solid polyureathane bush).
Resident grumpy old fart
