Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Perfect wheel alignment settings for the Polo??
    Feb 2007
    Brisvegas
    I know I may be asking a little much by wanting to find the perfect balance for a street/track car but here goes. All experience and opinions welcomed. Especially all the track whores out there.
    So a few questions to start things off. I believe the ideal front camber settings for a FWD car are between 3-4 positive degrees as printed here Suspension Tuning Negative Camber - Sport Compact Car Magazine
    Then there is front and rear toe and the Polo from factory is known for having around 7mm positive toe hence the Whiteline shims. So what would suggest as being the idea measurements?
    Then to front and rear camber. Now I know everyone would give their left one to have a set up like Eddy's but for us mere mortals I believe there may be a tiny bit of adjustment here. My last alignment print out says;
    Rear Camber
    left -1,35
    right -1,26
    Front Camber
    left -1,22
    right -0,50
    What are your thoughts on those?
    Cheers yal!
    I'm keen on this subject also Anyone?
    I also was looking into making adjustable strut tops... might start another thread on it to see if there's much support.
    Polo GTI MY2008
    Build Thread
    136.09kW and 305.28Nm torques, Dynapack Hub Dyno
    Feb 2007
    Brisvegas
    Did anyone manage to find their camber settings?
    May 2011
    Albury, NSW
    Didn't want to start a brand new thread for this - I got an allignment done a few days ago, first one since changing the suspension and the car had been pulling pretty hard to the left. Got in it and drove straight to Melbourne - 300+ kms of Highway driving and it's still pulling to the left exactly the same before it was apparently alligned - surely this isn't normal? Have I been screwed over?
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    Jun 2008
    Ringwood, Victoria
    Perfect wheel alignment stettings for the Polo??
    Ask/check your receipt of work done because if it mentions camber adjustments, they're lying. They can adjust toe but for castor and camber, they need to unbolt the whole subframe.
    May 2011
    Albury, NSW
    Quote Originally Posted by gavs View Post
    When I picked it up they said something about +1 Toe - wasn't really paying attention, it'd been a long week.
    I was expecting an allignment to correct the pulling to the left. I know all car's will pull eventually because of camber, but this is a soon as you let go off the wheel, harsh pull. Would I be out of line if I took it back and asked them to re-do it?
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    I thought mine pulled to the left, same story, fitted new suspension and thought it was that..
    It still pulls to the left mainly, but I think it's just because of the bigger wheels combined with the camber of the road as it can pull to the right sometimes as well. It sounds like yours might be a bit more severe though?
    Polo GTI MY2008
    Build Thread
    Jun 2008
    Ringwood, Victoria
    Don't forget also that the inherent backlash in the drivetrain accounts for this as well with the 2 different length driveshafts, the left being shorter. Find a hill and with the engine running, put the car in neutral and roll down seeing if the pull is the same. I would also ask exactly what they aligned because if they haven't given you a report on the before and after settings, I would question the workmanship...
    Oct 2010
    Melbourne, VIC
    They should be able to print out a copy of the alignment settings (with both before and after measurements) from your previous visit. Certainly make sure you get one if they realign your car.
    Usually, they will set cars to pull slightly to the right if you don't ask for a straight track.
    Resident grumpy old fart
    What are the rear wishbone bushes like?
    Have they been replaced, you could align it until the cows come home and it would change significantly between power on and off, if the bushes are worn out.
    You could set it correctly with no movement on the ramp but that changes on the road.
    Quote Originally Posted by nightphotographer View Post
