Results 1 to 10 of 14
Thread: Replacement VW 3-Button Flip Keys
    Feb 2008
    Kincumber, NSW
    While I have sourced two replacement keys - Part No. #HLO 1JO 959 753 DA - for a Polo GTI that have the correct TRANSMITTER inserted in the top section of the key to lock and unlock the doors of my car - the all important TRANSPONDER chip located in the lower part of the key (behind the swinging blade section) that were originally supplied with key by the UK supplier is not the correct type for the Polo GTI.
    Do any Forum members:
    1. Know where the suitable ID48 glass TRANSPONDER chip can be purchased in Australia?
    2. Know of any Sydney area non-VW Dealer sources who have the equipment and technical skill to match the new key TRANSPONDER to my Polo GTI's immobliser system?
    3. Know of any Sydney area Locksmith who has the laser cutting equipment to successfully cut a new VW swingblade key?
    I will appreciate any constructive feedback from Forum members who have the special knowledge of the VW key programing subject.
    Aug 2008
    By the sounds of it it would have been much easier going through a local VW dealership (although probably much more expensive).
    Cheers,
    John
    i got my blank switchblade cut at rhodes shopping center $35
    Jan 2009
    blankedy
    When I was looking into a spare key, was told the only way to get it was from VW in Germany (as they do not onsell the blanks to 3rd party companies). The key is then cut based on the cars individual details (had to provide chassis number).
    Once locally received, the individual programming for the car is done at the dealership.
    I was quoted around $400ish for the full functionality key.
    I got a very basic plastic one (with full chip functionality, but no remote features) for less than $200 (think around $170).
    Was happy when I used it the other day, if you don't put the key in the ignition and start, the alarm goes off. When locking from the door, alarm activates.
    Feb 2008
    Kincumber, NSW
    Yes - if we were all rolling in cash and prepared to pay up to $424 - we could present ourselves to the VW Dealership, who would be very happy to relieve us of our hard earned cash.
    This replacement VW key subject is an interesting one - as it seems that there are a variety of Forum members who have "bits and pieces" of information on the subject.
    From my limited experiences in researching everything that has transpired on the replacement key subject on this Forum and various overseas VW related forums - there are ways to come up with replacement keys for the Polo GTI without resorting to the services of the VW Dealer.
    In the case of the Polo GTI there are three essential components to having a fully functioning replacement key:
    • Item 1 is the 3-button top half of the key with the correct TRANSMITTER with the part number HLO 1JO 959 753 DA that handles the door and hatch locking and unlocking functions. There is a simple self-programming procedure that can be followed where the new key learns the programming codes from the old/existing key - without having to get the VW Dealer involved.
    • Item 2 is to get a correct laser cut of a new key blade. In this respect, a key number was originally attached to the two new keys when our cars were delivered by the dealer - that enable Locksmith's with the right equipment to program cut a fresh key blade from that number. Alternatively, connecting a VagCom or similar diagnostic instrument can obtain what is known as the SKC (Secret Key Code) from the cars onboard computer. However, it is still possible for a savvy Locksmith with the right equipment to duplicate a key from the original cut impression.
    • Item 3 is to acquire the correct ID48 glass TRANSPONDER which is located in the lower area of the key behind the swinging key blade - and to have this Transponder programmed to be recognised by the rolling code ignition immobiliser that is built into each of our cars. I am told there are non-VW Dealer businesses - mostly high end Locksmith companies - that can do the required TRANSPONDING programming that will allow the car to start after being recognised by the onboard ignition immobiliser - and not cut out after 2-seconds.
    Let's collect as much positive information as we can on this subject and beat the prohibitive VW Dealer costs to simply replace a key.
    Jan 2009
    blankedy
    When I bought the key there were 2 costs:
    1: the plasatic 'blade' (supplied cut). (super basic version was around $110)
    2: local programming for identification. (around $60 from dealer).
    I assume if you could find the right blade with transponder and get cut, you could take it to the dealer for the transponder coding...
