MAKE: 2006 Polo GTI 9N3
KMS: 104,000
CAR USAGE: Daily
PROBLEM:
Hi guys, been having a few problems with my Polo for a while now.
Basically at the moment the car has a loud screeching noise under high throttle (I suspect a boost leak but hey I'm no expert). Additionally, the turbo does not seem to be spooling up as quickly as it used to. For example, when I first purchased the car, gentle acceleration in 2nd gear would have the turbo spooling up nicely - could hear it very prominently over the engine noise. Currently you can't hear the turbo spooling at all all the way through 2nd gear (almost to redline) but I do get the horrible screeching noise. The same is true for almost all driving situations EXCEPT putting it into 5th at say 80km/h and applying half throttle, you can hear the turbo spooling nicely. Sometimes low to medium throttle in 4th gear at medium speeds (say 70-80km/h) will have the turbo spooling nice and smooth.
FINALLY, the car seems to have a very subtle misfire at idle. Sitting at the lights the car will be idling at say 750/800RPM, then sporadically drop about 50-100 RPM and pick up again. I'm not sure if this occurs at a regular intervals. I can only describe it as an occasional stutter in the idle.
Oh and I recently had an exhaust leak fixed on the dump pipe but I suspect the guy didn't fully weld it up... looks as though there is still a gap between the welding.
Any thought on what could be wrong with my Polo? I've done a heap of research and can't find people with the same symptoms as me.
Appreciate your help guys![]()
