yes. understood. torque peak shifts lower down the rev range with less throttle due to pumping losses being constant vs power produced per stroke decreasing.
This thread is about maximising acceleration so unless the car has very bad tuning of some sort so it's stumbling at some point of the rev range, then WOT is a given.
Back on topic, for peak performance, you generally want to shift past the power peak so that the engine has delivered the most that it can and you would like to shift into as high in the power curve as possible so the engine keeps driving as hard as possible. The torque peak (where the most energy is delivered per stroke) is basically irrelevant as it is the RATE of energy delivery is what matters (the actual definition of power) and this is the product of the energy is delivered per stroke x number of strokes (torque x rpm).
Operational impediments are the only reason the don't do this when trying to maximise acceleration.
Going beyond the redline is a bad idea from the engine longevity point of view and also many engines will drop power dramatically beyond the power peak any way (be it naturally or with rev limiters).
jasn78, at what rpm does your engine deliver peak power?
Resident grumpy old fart
