Originally Posted by
seangti
Anthony, from my understanding, the outcome to your approach would really only be applicable to reach that arbitrary figure or distance. So for quarter mile, shifting at optimal points for 1st and 2nd gear would accelerate faster than holding onto them till cutout, but holding 3rd to cross the line may be faster. Reason being, that once the gear is beyond it's efficient power delivery, the next gear WILL accelerate faster. This is probably best explained in the g-force graph, post 5800rpm for me, 3rd gear pulls more g's, which is accelerative force.
Also perhaps worth bearing in mind that each manual shift takes an average of 0.8 seconds which is also backed up from some runs I've done and Ben (aka Machine in his Golf R). If you run similar tests to me in gears 1-4 stretching them out to cut out using gtech (I'd need the raw data so must be the RR version), I could reasonably easily model the differing quarter mile times pending shift points. Though I'm not keen revving my car into/beyond red line, though your mods and tune may/could likely yield differing results to my entry stage 1 level of mods.
I had some discussion on the mkVl forum comparing DSG to manual (specific to R's), DSG shifting in about 0.1 secs. That doesn't mean you lose 0.7 off your time per shift, just 0.7 of full throttle per shift, I.e. robbing 1.5+sec of foot to floor board over a ~14second run.
Food for thought hey. (PS, if Im interpreting any of the data incorrectly, please correct me)
