The quaife is basically the same as the peloquin which eddy didn't like and which Peter Jones says is noticeably less effective than the wavetrac is his MkI track cars.
With those big front brakes, you will quite possibly find your car better balanced if you upgraded the rears, especially on turn in as you ease off the brakes.
What's the thinking behind the 16x8's Stuwey? You won't over tyre a 7.5" rim without modifying the guards.
Resident grumpy old fart
