wow. battery?
do you have a multimeter? How old is the battery?
Got in the car today. Nothing. Nuddah. Zip. Zero. Errrr?
wow. battery?
Yeah, you're right, does not make sense. Fuse?
Any modifications? Anything you've done to the car lately or at all? What's the scan saying?
strange.. use VCDS to do final control on the dash insert to see if you get the display up... try disconnecting the battery for 10 mins and then back on again... so many problems are cured with a battery reset there days...
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Double check the wiring of the head unit, also check the battery charge with a multimeter, very odd..
2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
Does the head unit turn on and of with acc power?
If it is battery, i'd be surprised if the LCD didn't light when the central locking worked, but who knows how many amps these elements need.
