Jesse battery I think is about a year old
Had a similar problem after installing a headunit Had the ACC and permanent wire reversed Ran the battery flat and i t was a fairly new one at that
Head unit could be hooked up to the constant +12v, slow drain
2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
I'll reset the battery tomorrow
wiring has been triple checked. Gav can confirm.
yeah it is wired with a switched 12v source (acc).
going to check the fuses tomorrow also.
the switched 12v source is DEF NOT wired to the constant 12v source.
battery has spot on 12.43v too
Just replaced a blown fuse.. still nothing.
Disconnected the battery for 10 mins. still nothing..
will scan it tonight..
may be clutching at straws and a random idea, could the earth be a dud? Can check with voltmeter, obviosuly +ve on the battery and -ve on a body panel.
Daily: 2010 VW Jetta Highline
Could be the cluster itself is bad or has a bad connection. Not hard to remove.
Sucks man.
Cluster reboot, at the source, ie plug off cluster and refit.
Alba European
