Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: ok. what is wrong with this picture?
    Jan 2012
    Got in the car today. Nothing. Nuddah. Zip. Zero. Errrr?
    Jan 2009
    blankedy
    wow. battery?
    do you have a multimeter? How old is the battery?
    Jan 2012
    wow. battery?
    Not sure how old the battery is..
    Yeh ill check the voltage on it. Doubt the battery wpuld cause this though.. both are dead?!
    Jan 2009
    blankedy
    Re: ok. what is wrong with this picture?
    Yeah, you're right, does not make sense. Fuse?
    Adelaide hills, SA
    Any modifications? Anything you've done to the car lately or at all? What's the scan saying?
    Jan 2012
    Yeah possibru.
    I'll have a gander around.
    To be honest, im EXPECTING the dash to need to be replaced so IF it is that, im not annoyed or dissapointed when I have to shell out hundreds of dollars to fix it instead of a 10c fuse.
    Jan 2012
    Nope. Havent done anything except put my headunit back in but it worked for a day and half before this..
    Just got in the car today and they are both a no-go.
    Havent scanned yet. Hoping to see gav soon
    Mar 2013
    Brisbane QLD
    strange.. use VCDS to do final control on the dash insert to see if you get the display up... try disconnecting the battery for 10 mins and then back on again... so many problems are cured with a battery reset there days...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Melbourne, Vic
    Double check the wiring of the head unit, also check the battery charge with a multimeter, very odd..
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    Jan 2009
    blankedy
    Does the head unit turn on and of with acc power?
    If it is battery, i'd be surprised if the LCD didn't light when the central locking worked, but who knows how many amps these elements need.
