Results 11 to 20 of 23
Thread: ok. what is wrong with this picture?
    Pacific Paradise QLD
    Had a similar problem after installing a headunit Had the ACC and permanent wire reversed Ran the battery flat and i t was a fairly new one at that
    Dec 2006
    Jesse battery I think is about a year old
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Melbourne, Vic
    Head unit could be hooked up to the constant +12v, slow drain
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
    Jan 2012
    Quote Originally Posted by vdubmotorworx View Post
    strange.. use VCDS to do final control on the dash insert to see if you get the display up... try disconnecting the battery for 10 mins and then back on again... so many problems are cured with a battery reset there days...
    I'll reset the battery tomorrow
    Quote Originally Posted by flat6 View Post
    Double check the wiring of the head unit, also check the battery charge with a multimeter, very odd..
    wiring has been triple checked. Gav can confirm.
    Does the head unit turn on and of with acc power?
    If it is battery, i'd be surprised if the LCD didn't light when the central locking worked, but who knows how many amps these elements need.
    yeah it is wired with a switched 12v source (acc).
    going to check the fuses tomorrow also.
    the switched 12v source is DEF NOT wired to the constant 12v source.
    Jan 2012
    battery has spot on 12.43v too
    Just replaced a blown fuse.. still nothing.
    Disconnected the battery for 10 mins. still nothing..
    will scan it tonight..
    Jan 2009
    may be clutching at straws and a random idea, could the earth be a dud? Can check with voltmeter, obviosuly +ve on the battery and -ve on a body panel.
    Daily: 2010 VW Jetta Highline
    Jan 2012
    Eh I doubt it.
    Will test anyway...
    Might sell up after this is fixed. A few to many gremlins for my liking.
    Jan 2009
    blankedy
    Could be the cluster itself is bad or has a bad connection. Not hard to remove.
    Sucks man.
    Aug 2007
    Cluster reboot, at the source, ie plug off cluster and refit.
    Alba European
    Jan 2012
    Quote Originally Posted by Jmac View Post
    yep.
    did this...
    absolutely nothing.
    So,
    where to find a new cluster and expect a forsale ad
