Results 11 to 20 of 31
Thread: oil feed line for turbo
    Sep 2010
    Wheelers Hill
    yeah ive got an f23 in the works on my a3 and have an lsd, bigger sway bars, coilovers
    oh im putting stronger internals as well
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Aug 2012
    Sydney NSW
    Is it just the rods that your'e changing?
    Sep 2010
    Wheelers Hill
    Rods and bigger pistons, rods are the only thing which is necessary though
    Audi A3 1.8 T
    Aug 2012
    Sydney NSW
    How do you find the ECS stage two clutch?
    Not sure how long my clutch is going to last after doing build.
    Sep 2010
    Wheelers Hill
    im putting the LSD and clutch at the same time, currently unlicensed so I told my mechanic to have to car done by the end of the three months
    You should consider putting an LSD at the same time
    Audi A3 1.8 T
    Aug 2012
    Sydney NSW
    Sort of spent a lot of money at the moment. Bought the car cheap so I had some money left over for some upgrades.
    I don't thrash my cars but not expecting miracles with this clutch. When it goes it will be an excuse to upgrade.
    What sort of power are you expecting?
    Sep 2010
    Wheelers Hill
    Around 200 atw, my car went in for a clutch change initially and its coming out with a total engine re build
    Audi A3 1.8 T
    Aug 2012
    Sydney NSW
    LOL. And how long do you reckon you're going to keep your licence once you get it back?
    Sep 2010
    Wheelers Hill
    don't wanna even think about it, probably book a couple of track days to push it hard
    Audi A3 1.8 T
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Redliner View Post
    I think that one is for the older (6N) Polo. Almost certain the 9N3 has the 02J gearbox but the problem is figuring out which ring gear (114mm or 113mm) was used. I want to get the Wavetrac as it has a plate that loads up the wormdrive to lock the diff if there is excess slip on one side (with no grip on one axle, the Quaife, Peloquin and Torsen still spin like an open diff).
    Resident grumpy old fart
