Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: oil catch can
    Jun 2009
    PJ/Selangor, Malaysia
    Smile oil catch can
    anyone done this for our car? i would be interested to know
    a) where you mounted the can / tank?
    b) where do i attach the hoses?
    thanks.
    Feb 2007
    Brisvegas
    I'm going to have a crack at installing this one for a MK4 Golf GTI this weekend
    Catch Can Breather Kit, MK4 1.8t - 034 MOTORSPORT
    I will let you know how it goes!!
    Jun 2009
    ok! will wait for your successful results
    Aug 2009
    im curious as to why you think you will need one?
    our vw's normally are fine with the factory arrangement, especially since VW spent time making sure it all worked.
    are you consuming oil and suspect its coming out as vapour via the pcv?
    if so, i'd investigate the reason behind this.
    unless your car is heavily modified and its always in the higher rev range, in which case you'll need one.
    or you have an old chrysler....
    06 Polo GTI
    standard ECU, wheels | K&N Panel filter | PD160 intake tube and trumpet |Nulon 5W-30 | Michelin contact sport 3
    Feb 2009
    Liverpool, Sydney
    Quote Originally Posted by blackbetty View Post
    Read and learn..
    • View topic - Carbon build up
    BLACK 2.0 FSI Jetta -
    Transforms - http://www.youtube.com/watch?v=SgjFFxjkZlQ
    Feb 2007
    Brisvegas
    Do you class a Phase 3 tune which more than "Doubles" the factory HP output a heavily modified car???
    Carbon build up is not an issue on a Polo GTI with port injection - It is however a big problem on direct injection cars (like MKV & VI GTI's)
    Aug 2007
    Ive had plenty of 1.8Ts stripped down due to carbon, here and the UK. Main problem was carbon build up in the oil feed and return pipes, changed plenty of turbos as a result, oh and must not forget a couplke that had missed a few services and then got fresh nice oil and all the carbon made its merry way into the oil pick up in the strainer and the result the oil light stays on and its a sump off to at least clean the strainer or if you are unlucky its a new pump and a set of shells. Also in the field have just looked at a 1.8T Audi which was an APU , so turn it around and you have an AGU, AJL, BAM etc and someone had fitted a new turbo because it had failed and never checked the reason why it failed. So new turbo goes on and fails soon after. On inspection the inside of the turbo oil feed was Clean, as in it had little or no lub. Result another blown turbo. It really pays to check why the failure in the 1st place, anyway moving along , my opinion is the whole range is bad for carbon if they are not serviced regularly and correctly. Im in no way disputing the direct Inj ones are bad , actually i do agree there, i check the cap when i do the service ( oil cap ) and ive seen a few with a fair build up there, so if its bad there how bad is it in the guts???? Hmmm.
    By the way Anthony didnt realise when i spoke to you today you got it from 034!! These guys are onto it mate, dealt with them for decades,i actually helped a guy on here JVLR32 on here with his race car, he was looking for a gearbox mod and i knew these guys were heavy into that, followed them for years mate so all good
    Jmac
    Alba European
    Feb 2007
    Brisvegas
    Sorry guys as it turns out there is no fuse box bracket on the Polo's fire wall like there is on the Golf so Jimmy is going to fabricate one for me soon!!! Thanks Jmac.
    Jun 2009
    any progress on this?
