Catchcans all come down to the mechanism inside, that is, just how much oil it actually "catches".
Not that I'm a world expert, but the TDI's suffer dramatically from oil blowby with their high compression, and I have a top end Mann and Hummell Provent and even it struggles to pull all the oil out of the blowby. The generic ones you see on ebay do very little, but adding some thick stainless scouring pads will help the oil condense and settle to the bottom. Just don't pack it too tight, it has to flow! The next step are the nicer ones from 42DD and Allards in the UK, both of which I'd love to get a sample of and test against the purpose built Provent. Allards seem to be a cheap yet possibly nice bit of kit, worth investigating, but I can't vouch for the effectiveness. I'm keen on a 42 DD cat back to be honest, so if you're not in a rush, perhaps we could combine and organise a 42 DD group buy.
Venting to atmosphere is illegal, and as I've played around with the oil blowby extensively, I have to say it's tremendously smelly at idle, enough to make you and those around you ill. I'd HIGHLY suggest venting the remainder back into the inlet, or at the very worst into the exhaust as the older muscle cars used to do. This is still an illegal mod these days.
Finally take it from me you really need to make sure your blowby system can flow the sheer amount of blowby gas, for my first early attempt saw me force oil out my turbo seals, which sure made for a bit of smoke. Be sure to keep your plumbing big, and remember elbows and the like often go down considerably in size, and a lot of hose etc that is readily available at the hardware will melt or in the very least deform in the engine bay heat. I spent eons trying all manner of hose until I stumbled upon the nice silicon stuff that is both flexible, oil and heat resistant. It's indeed tough to find, and I've wasted a lot of money at specific hose suppliers in my quest.
Interested to see how you go, but yeah, it's a highly recommended mod, especially in the oilers.
