Here’s what the locking tabs look like on the eurovox 8790
All 4 need to be pressed in at once
I need to remove the OG radio/cd player (Eurovox 4680) to find serial number for code but it won't budge. Took it to a radio installer who used his tools and he couldn't get it out either. What next?
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
Ahhh, okay, thank you. I think the clips might be messed up so those silver tabs can't be pushed down to release it![]()
How long in your tools push in, if you can reach further where the hook is you might get lucky.
Otherwise I am not sure if there is access from the sides, you may end up needing to break the bezel of the radio.
I ended up forcing it out with flathead screwdrivers. The clips were quite bent but fixable. Thank you.
