Page 47 of 56 FirstFirst ... 374546474849 ... LastLast
Results 461 to 470 of 555
Thread: The Official Polo Tyre Thread
  1. #461
    Sep 2006
    Tweed Heads
    Quote Originally Posted by VWindahouse View Post
    Just to clarify why I posted the one's I did. Both Pete and myself are after a street/track semi. For me there is actually a control tyre in one of the races I plan on doing in the future being the Yoko, and the other has a rating restriction that won't alloy the hardcore stuff you've had success with. So I figure I should practice with what I'll be racing with
    Hoyhoy.
    Well Ant. I like the RSR's, but the Yokohama AD08-R's seem to be getting very close to semi's going by that Speedhunters article ya put up.
    Hooroo.
  2. #462
    Nov 2012
    I'm really after something you an get in and belt immediately, a hill climb and traditional gymkhana tyre. The sort of tyre doing 500km on a sunday meet wont destroy.
    I rode in an improved prod 3j Cosworth powered escort ten years ago with what I think was the control tyre at the time, a 205/60/13 Yokohama a032 and that made enough grip to hurt. That is where I'd like the polo positioned. The more I think about it a 205/45 or 205/50 16 on standard rims will work very very well, and looks stock except for the tread pattern. Important when explaining away your sins to the police. $2000 saved on rims buys a lot of front tyres.
    Eddy, did you ever settle on your track tyre?
  3. #463
    Sep 2006
    Tweed Heads
    Quote Originally Posted by Bullet Fast View Post
    Hoyhoy.
    Quote Originally Posted by Eddy View Post
    P.S. I'm running 225/45/16 (rims = 16 x 8 with 35mm offset) for the track which is a common semi size (but not in a road tyre) & is a lot smaller in height than the 215/45/17 & only 5mm higher than the 215/40/17.
    I'm happy with this combination, funny enough using --- "YOKOHAMA" --- A050's, got me my PB @ Waky. (sub 1'10", just). I still have a smile.
    Hooroo.
  4. #464
    Nov 2012
    Hoyhoy.
    These were custom made wheels?
  5. #465
    Oct 2010
    Melbourne, VIC
    Semi slicks are actually pretty tough due to the relative lack of tread
    I destroyed my stock front tyres on my first track day and with semi slicks on my next visit, I went faster and the tyres had no wear problem (I had delamination issues but that's another story).
    As for a painful amount of grip, I used a run up our local twisty roads to scrub in my latest set of semis and after 18km of really tight stuff scaring myself with out going anywhere near the tyre limits, I had a sore neck.
    Mine are 205/50R15 A048s
    Resident grumpy old fart
  6. #466
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Not custom made, but had to be made (in sliver) as none in stock anywhere, they are heavy but solid.
    The Official Polo Tyre Thread-146_1_z-jpg
    Hooroo.
  7. #467
    Nov 2012
    Thanks!
    Sent from my GT-I9505 using Tapatalk 4
  8. #468
    Sep 2006
    Tweed Heads
    Quote Originally Posted by kaanage View Post
    Hoyhoy.
    Greg I usually do a gentle running of new semi's, I buy from Gordon Leven @ Penrith then do a easy drive down to Goulburn.
    Bill from Gordon Leven reckons that this a great first heat cycle for new semi's, so that's what I do.
    Hooroo.
  9. #469
    Oct 2010
    Melbourne, VIC
    I drove up the Reefton Spur going as fast as I dared, faster than any other time I've been up on any machine, and the A048's just went around the bends, no fuss, no bother and were barely warm to touch when I pulled over at the top. The break in was gentle compared to a track session but demonstrated to me just how much better semi-slicks are than normal tyres.
    The Neovo AD08R's must be pretty good but on track, I'd bet they would fall apart more quickly than A048/A050's. Where they would be far better is as daily use tyres - the A048 is noisy and harsh (feels/sound like you're driving a stiff 4WD) and aquaplanes like a bar$tard once there is standing water on the tarmac and I doubt the A050 is any better (the difference is the tread pattern of the A050 is supposed to make the tyre less prone to overheating). I'd also imagine the AD08R wouldn't heat cycle in road use like the full semis.
    I can't find the proper UTQG rating for the AD08R (TireRack have the same as the AD08 at 180) - the A048/A050 is 100 and the AD08 is 180 so I'd guess the AD08R would be around 140, like the Federal 595R (for persprective, the Kumho V810R is 30!!!)
  10. #470
    Sep 2006
    Tweed Heads
    Hoyhoy.
    I think the biggest difference will be that with semi's is that they won't go mussy as quick as good streety's because of less side wall flex.
    Hooroo.
