Page 25 of 56 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 555
Thread: The Official Polo Tyre Thread
  1. #241
    I had a set of the Adrenaline's, they were great. Grippy, lasted a while and were quiet too.
    Cheap, Fast, Reliable. Choose two.
  2. #242
    Jan 2010
    215/40/17 - Marangoni Zeta or 225/40/17 Kuhmo KU36?
    Will be using for street with occasional track. Based on budget. Opinions?
  3. #243
    Anyone had any experience with Kumho KU21 or KU23s?
    I have been offered these at $240 and $150 respectively in a 215/45/17 but i'm unsure if these are nice or not.
  4. #244
    Sep 2006
    Quote Originally Posted by Stuwey View Post
    Hmm at that price why dont you go the KU36 or KU31
  5. #245
    Aug 2009
    Quote Originally Posted by vwthunder View Post
    I have to agree. I have the KU31's and they are excellent for the price (I paid $106 for 205/45/16).
    Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
    Current Ride: Evo 8 MR, Fabia MK3
  6. #246
    Sep 2006
    I will be going the KU31's I got quoted a really cheap price from QLD in a 205/40/17
    I would rather have a KU36 but i dont want a 215/45/17, if i was getting that size i would get the KU36's
  7. #247
    Jan 2010
    I'm still thinking about this as well. I want KU36 but not sure if 45 will sit too high. I can lower it, on B8's + HRs but will need to work out whether it will scrape? Anyone running 215/45/17 without any problems?
  8. #248
    Jan 2009
    blankedy
    Depends on your offset / wheel width.
    I'm running 205's with a 32 offset and 7.5 wide wheel. the stance is perfect (well, legal) but I think the extra rubber would make it rub. Should work fine with a lower offset, I think a 40ish offset should work fine with a 7" rim (as long as it clears your suspension).
  9. #249
    Jan 2010
    Hey Ben, hope you're doing well.
    I got 17 x 8 +35mm offset. I know Kelvin runs these fine on 215/40/17 but want to know if this would fit fine on 215/45/17 with B8's and 35mm HR springs. Will probably need to do more research.
  10. #250
    Jan 2009
    blankedy
    Not sure mate... I'd think that with the 35 offset but 8" width you'd be sitting pretty wide...
    According to the 1010 wheel offset calc, you have 3mm more poke, 8mm less inside clearance for the rim...
    Doubt you'd get 215's to fit without rubbing on the H&R's, but I'm not experienced in this area... The H&R's sit a little higher, but seem to allow more travel than my setup. I think the 205's would look sweet, slight stretch but still inside normal wheel - tyre fitting spec.
