215/40/17 - Marangoni Zeta or 225/40/17 Kuhmo KU36?
Will be using for street with occasional track. Based on budget. Opinions?
I had a set of the Adrenaline's, they were great. Grippy, lasted a while and were quiet too.
Cheap, Fast, Reliable. Choose two.
Anyone had any experience with Kumho KU21 or KU23s?
I have been offered these at $240 and $150 respectively in a 215/45/17 but i'm unsure if these are nice or not.
I will be going the KU31's I got quoted a really cheap price from QLD in a 205/40/17
I would rather have a KU36 but i dont want a 215/45/17, if i was getting that size i would get the KU36's
Depends on your offset / wheel width.
I'm running 205's with a 32 offset and 7.5 wide wheel. the stance is perfect (well, legal) but I think the extra rubber would make it rub. Should work fine with a lower offset, I think a 40ish offset should work fine with a 7" rim (as long as it clears your suspension).
Not sure mate... I'd think that with the 35 offset but 8" width you'd be sitting pretty wide...
According to the 1010 wheel offset calc, you have 3mm more poke, 8mm less inside clearance for the rim...
Doubt you'd get 215's to fit without rubbing on the H&R's, but I'm not experienced in this area... The H&R's sit a little higher, but seem to allow more travel than my setup. I think the 205's would look sweet, slight stretch but still inside normal wheel - tyre fitting spec.
