Page 53 of 56 FirstFirst ... 3435152535455 ... LastLast
Results 521 to 530 of 555
Thread: The Official Polo Tyre Thread
  1. #521
    Nov 2012
    WA
    The 215/45/16 rt-615k is recommended for a minimum 7 inch rim, so you shouldn't run it on stock rims
    Mixed reviews on them, ok for short sharp work but any extended period on track and they go greasy
    I'm going to try a set of RSRs
    08 9n3 Polo GTI
    Mods: heaps
  2. #522
    Apr 2014
    Perth
    Ah, thanks for that. Surprising that 10mm more tyre width would mean a wider rim. No track work for me, just want a really grippy street tyre in the dry.
  3. #523
    Apr 2014
    Perth
    You getting the rsr's from tyre power?
  4. #524
    Nov 2012
    WA
    Yes
    I've got 2 sets of rims, I'll prob only use them at the track. Get some re003s for the road when they do the 4 for 3 deal.
    08 9n3 Polo GTI
    Mods: heaps
  5. #525
    Nov 2012
    WA
    Got the RSRs on
    140 treadwear compared to re003 220, so they won't last long
    Road noise, I don't really notice anything major. My pog is obnoxiously loud on jandal though.
    08 9n3 Polo GTI
    Mods: heaps
  6. #526
    Apr 2014
    Perth
    Grippy?
  7. #527
    Nov 2012
    WA
    Chased pressures a bit at the track last night
    Pre-reading suggested a fairly high hot pressure, around 38psi, to stop side wall flex
    Seemed reasonable at that didn't seem to chew them up. Front left copped a bit as it always does but not as bad as the re003. I think it may have been running the re003 a bit soft I can't remember what pressures I ran them at that track last.
    The pog is normally a bit tail-y if you're aggressive through the esses with the re003 and no rsb. With the rsrs and the rsb on hard it was pretty solid.
    Will probably do Collie in December on them I push a bit harder there as it's more forgiving.
    08 9n3 Polo GTI
    Mods: heaps
  8. #528
    nsw
    Blue9N3 if you get the newer RSR-R they have a treadwear of 200 compared to the earlier RSR which is 140, so if you're worried about longevity they might suit you better than the earlier 595's.
  9. #529
    Apr 2014
    Perth
    Just noticed for the first time after 3 years that the recommended pressure on the fuel cap is 38psi....I'm assuming that's a cold pressure? Been running 34 for some time now. Tried 38. Steering much better, wheel spin far worse...
  10. #530
    nsw
    yep cold pressure 2.6/2.4 bar or vice versa from memory. Yeah if your on a decent tyre with a stiffer sidewall you will be able to get away with lower pressures that help straight line grip under power like you found. The 38psi they recommend is a one size fits all safety recommendation for monsoon, dry, snow, hot, cold for nanna and the family. While you sacrifice lighter steering, fuel economy and aquaplaning resistance you'll proabably find more outright grip on the pressures you've been running in the dry if the sidewall stays reasonable.
