Love my RSR's on the front, can't compare them to anything tho
Pretty cheap too considering
http://www.tirerack.com/tires/tires....D08R&tab=Sizes
For someone chasing ultimate performance, I think that any change in wheels should be dictated by the level of grip and performance you want from the tyres, which in turn, depends on tyre availability.
The Toyo Proxes R888 should have a much softer compound than the Yokohama Advan Neova AD08 (the R888 is in a different performance category after all) so it should work better on the track.
The R888 is available in 205/40 R17 84W XL, so you should aim to get a 8.0 J x 17 wheel (or make do with 7.5 J x 17 depending on what fits).
Otherwise, keep the stock wheels, fit AD08 tyres in 205/45 R16 83W, and use the money saved on other mods.
I don't see the point in changing to wider 16" wheels, because you end up fitting the same AD08 tyres (even in 215/45 R16). If you're going to the trouble of changing wheels, make it worthwhile - go 17" & R888.
Hoyhoy.
Now what I'm going to quote here is only my opinion & is from what I have experienced.
Anthony, there not the real deal compared to semi's or tracky's, just have a feel of the side walls between the two.
Don't get wrong here, the tyres you mention are great for street & track, but, I say but because you are going to great lengths to gain future minimal fractions of seconds in circuit times when the tyres can gain ya a lot more in times than what you are doing @ present.
Please take no offense of what I'm saying.
I run RSR's for the street, love them when I do drive on the road & I've had Yoko's AD07's which are great also.
Here I ago again & say, BUT, but there is a time difference between these classes of tyres when ya hit the track.
You obviously haven't experienced tracking with the R888's,,, I've tried this size in particular & I would say that it is in a class lower than the RSR's which I had both on @ the same time. (front & rear)
Like I say, what I put up here is only my opinion.
P.S. I'll be quiet on this subject from now on, unless asked.
Hooroo.
Interesting, as you're not the only one who have had less than ideal experiences with the R888s on this forum. I've also read comments regarding its (over)sensitivity to inflation pressures.
You know, I wonder if Bullet Fast would be better of with a set of AD08 tyres in 205/45 R16 83W, rather than full-blown track tyres? IMO, that would negate the need for new wheels.
Such is the nature of tyres, naturally. What suits one car or driver may not suit another.
I don't see why not. I like to think that we value first-hand experiences and feedback, particularly when it comes to track tyres, and particularly when people take the time to express such views.
Yeah, a TDi guy said they feel like AIDS.
But then Peter Jones found they were fine on his white MkI track Golf - maybe they're best on light cars?
He doesn't want to go to larger wheels, anyway. He thinks 16's would be faster than 17's for the same brand/pattern.
Resident grumpy old fart
Eddy, mate no offense at all! You're clearly the most qualified to make totally just comment from your experiences, so don't think of not contributing such valuable information. That's what it's all about brother.
Just to clarify why I posted the one's I did. Both Pete and myself are after a street/track semi. For me there is actually a control tyre in one of the races I plan on doing in the future being the Yoko, and the other has a rating restriction that won't alloy the hardcore stuff you've had success with. So I figure I should practice with what I'll be racing with![]()
That I do sir, that I doYou know it's funny that I'm actually running out of time yet again to get/do everything I wanted to get sorted with the car rims and tyres incuded. And I think the Fiance has finally made up her mind on the wedding time and destination and all I can say is "OUCH". This little project just hit a large snag
