Originally Posted by
kaanage
I still contend that the 175 width XM2 is more than enough tyre for most Polos as I only held up one car in the group + the gentle and progressive breakaway characteristics make it very controllable as the limits are approached. In fact, even at a track day, it would be a good tyre for inexperienced drivers to learn with as they could learn the car's on the limit cornering behaviour and recovery techniques when overcooking a turn at slower speeds with highly predictable response.
After another cruise with these tyres (all 4 this time), I can confirm that while the limits aren't super high, they have a very wide performance plateau so you get loads of feedback as you reach the limits which allows you to slide the car quite controllably, if your chassis/suspension is well balanced. You also get audible warning from tyre squeal both in corners and under brakes as the Golf R I caught and passed will testify.
Resident grumpy old fart
