since there's going to be some testing of Polos with different levels of mods, I'm curious what ppl think of the following case studies -
- Timbo's Polo has hit 136 atw on two different dynos, with just an ECU flash and 3" dp. Any explanations for this??, eg higher psi.
- While I never dynoed mine with just the APR flash alone, my first dyno was just flash/CDA, and only got 120 atw. Then with FMIC (133.5) and then exhaust (145). Would it be fair to say that, rather than these mods 'adding' 12+ kw atw each, they were more the result of a cumulative effect, ie 133.5 not possible without the CDA etc.
I'm hoping this can lead to some interesting discussion about why some Polo GTI power outputs diverge considerably.
i see what you're getting at. it seems as though the SEAT intake also has a very minimal affect (as per many conversations on here) but maybe coupled with another mod/s that requires higher air flow it could be really effective in comparison to the stocko intake.....in turn showing higher hp/kw readings on the dyno. definitely a good point that needs some answering.
Cheers,
Rhys
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
Any idea of a date yet ?
I only plan about 2 days in advance, so I'm free![]()
