Results 1 to 9 of 9
Thread: OEM strut top nut
    nsw
    OEM strut top nut
    Went to check the strut top nut on the damper shaft was tight the other day. 22mm tube spanner was too small, 24mm too big. The damper shaft allen key size was just as weird - 6mm too small, 8mm too big.
    WTF! didn't know a 7mm allen key or 23mm spanner existed or is this strut some kind of imperial hitch hiker on our german spanish metric car.
    help with tool sizes please
    confused
    Quote Originally Posted by sambb View Post
    confused
    7mm isn't that uncommon Sam. I bought my first one aged 18 to do the brakes on an Escort XR3 and have owned one for 30 years now.
    Surprised that the 24mm didn't grip it enough to allow you to tighten it up though. TBH I use my battery impact gun for taking them off and that doesn't usually struggle
    Oct 2010
    Melbourne, VIC
    Is it an allen or a spline head? The ones on my Bilsteins are splined
    Resident grumpy old fart
    nsw
    24mm might have just but I never attempted because I couldn't get the right allen key anyway. Was also doing it with strut in the car in the work carpark at night with extension bits to get the allen bit down the guts of a tube spanner. I gave up very quickly.
    Ok good to know that 7's exist. I'll have another crack soon.
    nsw
    yeah pretty sure it was allen.
    brisbane
    not everyone is old enough to remember the days before fuel injection and i didn't think ford escorts had brakes? at least mine didn't as far as i can remember...
    i just bought one of these to remove the strut top bearing on the s3, i hope its the right tool. if it doesn't work can i just shock it off with an 18v impact wrench?
    Sealey Strut NUT Socket Audi VW Specialised Impact Sockets Strut NUT Tools | eBay
    Quote Originally Posted by guile View Post
    You shouldn't need that for a MK1.
    I have them anyway if you need one.
    Just gun them off.
    brisbane
    thanks mate, i'm hoping it does need the impact wrench as i've just bought a dewalt and dying to use it...
