im not(bias much)
i think it all boils down to this:
however agreeable we find each other, and however well we may get along with one another both on and off the forums, and however willing we are to help each other out as a result of some sort of communal sentiment, on the whole, as a group, from the outside looking in, we're probably a real bunch of pricks.
im not(bias much)
The Scangauge is adjustable as a percentage (%) of the speed shown on the car dial. It adjusts either positive or negative. I used a GPS unit, while on cruise control at around 110kms/h, to adjust the Scangauge.
If you simply just plug it in, the speed on the Scangauge will be the same as that on the car dial until you adjust it.
