Results 1 to 10 of 20
Thread: OBD II and Scan Gauge
    Hi All
    Sorry to be re hashing old posts...
    But all the post I have read are a year or 2 old and I was wondering what the best option is for getting some more info out of the PoGs computer??
    Is anyone still using either ODB II or the Scan Gauge setups?
    Any advice would be good.
    ~graham
    Jan 2009
    blankedy
    What info are you after?
    With a ebay OBD cable you can do a little, I have used an android app with the little $11 bluetooth obd tool.
    IMO, logging is good if you have an agressive tune, to tinker with timing you want lemmiwinks which requires a OBD cable (usb / serial)
    noone
    really only looking, I don't want to adjust anything at all!!
    I had an apexi power fc on a r33 and I liked to see what the car was doing.... max revs, speed, water temp etc..
    i'm happy to use the obd ii bluetooth jobbie if you can tell me which one to get???
    $11 seems a lot better than $180 for the scan gauge.....
    thanks
    ~graham
    Aug 2006
    Papua New Guinea
    I don't have one of these, but have heard good things about them on another forum (newbeetle.org)
    UltraGauge OBDII Scan tool & Information Center
    Greg
    2002 New Beetle Turbo
    Jan 2009
    blankedy
    The OBD reader app does not measure boost, so mostly pointless. The device is an ELM327. It's the chipset, many variations available.
    Feb 2007
    Brisvegas
    Got a link to the $11 OBD tool mate?
    Quote Originally Posted by VWindahouse View Post
    I just bought 1 for $12.99
    ELM327 Obdii OBD II OBD2 V1 5 CAN BUS Bluetooth CAR Diagnostic Interface Scanner | eBay
    Feb 2007
    Brisvegas
    Thanks, so it doesn't say it's compatible with Iphone 5. Is there an app or something to work with the two?
    Cheers.
    Cheers.
    From what i have read and asked others, android has several apps and a quick spin with uncle google showed iphone 5 apps on itunes...
    I dont really do iThings but you should be right....
    a few weeks until delivery for me...
    Sep 2006
    Tweed Heads
    Hoyhoy.
    Me have a Scan Gauge, but it's still in the box, will be playing with it soon.
    The reason I went for the Scan Gauge was for the factor that the speedo can be calibrated (couldn't find any others to do this) which I think will make it easier to set cruise control, I find it a pain in the butt with the standard set-up, even though the Little Blue Girl hasn't been out of the shed since last year, still in pieces.
    Plus the main reason me went for a OBD gauge is for inlet temps. while tracking.
    Hooroo.
