Results 11 to 20 of 21
Thread: OBD II bluetooth dongle - will it work in Polo GTI?
    Jan 2009
    blankedy
    yeah, i think ME7.5 in the Polo.
    Where is the boost sensor?
    Jun 2012
    Canberra
    ok... received my ELM327 today... had a bit of play with it.... the readouts are pretty accurate... however, it does not show BOOST PRESSURE!!! ARHHHH!!!!
    Is that with Torque, I can see it in my S3, I just picked a new gauge and scrolled down until I found boost.
    Has to be there.
    Jun 2012
    Canberra
    Has to be there.
    yeah.. i can get the boost gauge up in Torque, but it has no readout....
    Jan 2009
    blankedy
    We don't have a boost sensor. Using VCDS there is a readout, but its not a sensor measurement, thus why the cool digital displays in the TT's dont show boost in our Polo.
    Or so I believe / remember when I looked into it 2 years back.
    Jun 2012
    Canberra
    got it to work.... after installing Torque Pro (full version)... my boost peaks at 23psi.... I've for APR R1 DV and Stage 1 tune.... does it seem a bit excessive?
    Jan 2009
    blankedy
    its estimated from the MAF and something else, I don't think its excessive, but is a little higher than what you might see from a sensor / meter.
    Its not including ambient is it (sitting at 1 bar, 14psi) when idling is it?
    I just looked at the install PDF for the Forge FMIC they call it a MAP sensor in there. Manifold Absolute Pressure, VW call them thrust sensors in ETKA.
    http://www.forgemotorsport.com/media/FMINTPOLO.pdf page 17 item 28
    EDIT, 23 PSI as peak isn't silly, could be overboosting a touch but I don't see it blowing up. You would need to look at requested and actual boost at the same time for a proper comparison.
    Jan 2009
    blankedy
    Not claiming to be an expert here, but I believe its different. Having done a little logging earlier, I remember it used the MAF readings, not the MAP sensor. Again, not 100%.
    Some interesting info in the wiki: MAP sensor - Wikipedia, the free encyclopedia
    I had thought the MAP sensor was used for fueling, protection and N75 regulation, but I can't be assed working out where I got that from or how accurate it is (reading on places like Vortex can be blind leading the blind).
    Jun 2011
    If you go for a bluetooth dongle you should probably get one of these:
    http://www.vwwatercooled.org.au/foru...tml#post841292
    Scroll down a bit for an image, it reads ECU block values just like VCDS. jazd has one working with Torque on Android, he's making a label file for it. According to him a few posts down, the adapter is wbh-BT4 $70 or so from Germany.
