Page 10 of 16 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 160
Thread: Noone's Polo
  1. #91
    Jan 2009
    blankedy
    I had a 7.1 on my way to work, I'd expect mid 8's normally. When I'm in traffic, can go over 10 (per 100k from dash reading).
  2. #92
    Jul 2010
    Quote Originally Posted by seangti View Post
    half your luck, I just filled up in the high 9's. Since the tune I've been mid 8's at best and in the 9's.
    I work shift work so drive in non peak hour traffic mostly so i can cruise in 5th and i drive off boost if im just to and from work. Gets down to below 7L/100 easily on my commute and some 10L+/100 weekend driving averages out to about 8L/100 so im very happy with my cars efficiency / fun ratio.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
  3. #93
    Jan 2009
    blankedy
    My work drive is peak hour through the harbor tunnel, into Alexandria, so it's pretty stop-start at times.
    I certainly didn't change the valve for fuel reasons, but somehow the waste gate is being controlled in a way creating more power and saving fuel.
    I understand some of the theory, but it's strange to me...
  4. #94
    Oct 2010
    Melbourne, VIC
    Since the car is making more power at the same revs/throttle, you are probably using less throttle so you end up using less fuel.
    This is how diesel tuners can advertise that their tuning maps/boxes can make the vehicle use less fuel. Most people with petrol engines use the extra performance so they don't see the efficiency gains.
  5. #95
    Jan 2010
    Central Coast NSW
    I went to Canberra and back and got 5.9 (family 110km/h freeway cruising), which is mental. It's better than a Toyota Prius. The Funny thing is it's better now with the bigger turbo than it was with the stocker.
  6. #96
    Jan 2009
    blankedy
    Mini Update;
    Eclipse Head unit landed, few other bits on the way before it goes in.
    Bench Test:
    Ipod Control from head unit, comes with mic and bluetooth for hands-free
    Sound quality seems good for on the generic speakers we had lying around.
  7. #97
    Jul 2010
    What are you going to fill up the other DIN unit with? Gauge pod?
  8. #98
    Jan 2009
    blankedy
    pocket for now, not sure I want more distractions in my dash.
  9. #99
    Jan 2010
    Update needed!
  10. #100
    May 2011
    CAMPBELLTOWN
    Quote Originally Posted by pog View Post
    Update needed!
    agreed, one nice polo to read about!
    GIAC | FORGE | D2 | TURBOSMART | K&N | XFORCE |
