Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: New Springs.
    Aug 2009
    Cape Town , South Africa
    sup guys ... im considering changing my eibach 35mm springs ... i want to go lower ... does H&R have anything in 40 or 45mm ???
    Current - Polo GTI 2009
    ex- Mk1 old School
    Jun 2009
    Quote Originally Posted by G-VW-PGTI View Post
    H&R have an Ultra low coilover that drops to 40mm.
    Might want to Pm GTI Dave to see if he knows anything, especially since he has a Polo GTI himself.
    Feb 2008
    It took me about 3 hours to fit the all 4 springs myself, although, I used a 2 post hoist and had all of the tools.
    Rear springs take about 20 min to fit.
    Front springs were a bit more of a hassle.
    I found that removing the drive shafts from the hub, and undoing the 3 bolts that hold in the lower ball joint(13mm bolt) to be easier. you then need to remove the bolt that hold on the drop link, then the Tie Rod to the Hub Carrier, undo the center nut on the drive shaft(about a 30mm socket I think), remove the locating bolt where the strut goes into the hub carrier, then try and slide out in one motion. You will swear, and you will neen some Lanolin spray, or WD-40, as the parts can be stuck.
    Jan 2009
    blankedy
    Something like these are your best option: http://www.apcoilovers.com/ap_coilov...ils.php?id=216 They will go very low, cost about $1200.
    Apparently AP are similar quality / make to Weitech.
    Jan 2009
    the front is a PITA as others have suggested. It's not as straight forward as other vehicles, do your research before getting to the point of no return. There's a tool to get the strut out of the hub thing, make sure you have that, as banging with the hammer won't suffice and won't make life easy getting it all back together. (i tried, than gave up, remember point of no return)
    Also remember the subframe changes all castor settings, so could steer like a pig once done until you get an alignment.
    Most people have paid around $200+ from someone else to do it, for the grazed knuckles and cursing involved, it's money well spent IMO.
    Feb 2008
    Quote Originally Posted by seangti View Post
    I wedged the tip of a Cold Chisel in there to widen the clamp, then sprayed in some Lanolin, and the came out very easily.
    Also, you will not need to touch the sub frame to pull out your struts. The only thing you need to undo that is attached to the body of the car, and not the suspention is the 3 13mm strut top bolts in the engine bay.
    After all was said and done, I went to get a wheel alignment, and my setting were fine, and I didn't need any adjustments. I thought that was great!!
    Nov 2006
    Did any one see how limited travel the front arm has?
    Nov 2006
    Quote Originally Posted by Steve88 View Post
    Just a silly question i have no idea but by me installing the H&R 30-35mm springs does it stiffen up the car... i know coll overs will do the trick but i dun have the cash.
    just thinking them and the RSB and FSB might give it the right stiffness for my buck.
    any feed back would be nice.
    I say goes for H&R then control arm bushes first, definitely cheaper but may not be easier.
    Jan 2009
    blankedy
    Control arm bushes take a while to fit (for the little expense they are).
    I'd talk to your mechanic about what else can be done at the same time to minimize your labor cost.
