Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: New polo... With an issue?
    Sep 2014
    Quote Originally Posted by rollehgoo View Post
    I have a ECS stage1 clutch. And it chatters quite a bit when the clutch isn't engaged. Been told by a bunch of people in here and the dealer that it will chatter.
    Ah that sounds good.
    Thanks for the replies.
    I found out what the cel was too.
    CTS sensor.
    Does anyone have a write up on it? Or where the general location of this sensor is?
    It sits in the water pipe on the side of the head over the gearbox. Easy to change, just do it with the engine cold. Pull out clip, remove sensor, insert newie, fit clip.
    Sep 2014
    Thanks Gavin. I'll have a look. Wasn't too sure where it sat, and which one to change (there's apparently a 2 pin and 4 pin?)
    I asked in the other thread but might ask here too, know where to get one that's reasonably priced?
    ebay if you're not in a rush, VW if you are.
    Pretty sure they are all 2 pin. 06A 919 501A make sure you get a new O ring and clip.
    NEW Genuine Audi VW 2 PIN Coolant Temperature Sender 06A 919 501 A | eBay
    An expensive one
    Sep 2014
    An expensive one
    Thank you very much. Not in a rush, it's not effecting the drive too much anyway.
