Results 21 to 30 of 33
Thread: New Front Bushes for my Gti - who to install them in Sydney
  1. #21
    Quote Originally Posted by greg32 View Post
    I swapped ot the lca with superpro lca items. No odd tools needed if you do a swap. I also put in the remaining tyrolsport locators. The old arms were good but i wanted to put the front end on a diet. A wheel alignment is the only thing needed after the work.
    The Polo is built differently to the MK5.
  2. #22
    nsw
    Alright, based on your advice and considering that I'm keeping stock springs, I'm going for the superpro's. few more questions though: 1. are you replacing the LCA front bush at the same time with superpro too, or is it preferable to retain the solid OEM rubber bush for performance reasons and some degree of forgiving-ness? - mines only done 28k km's and i'll keep it if its no detriment. 2. Because the rear LCA bush is stiffer in the vertical plane, is it way harder to get the LCA pushed backwards into it whilst manouvering the front bush into the subframe? ie is there a high chance of damaging the original front LCA bush on re-fitment? 3. Because the superpro is eccentric and pushed in (and some have said just knocked in - no tool needed) has it ever been known to shift position rotationally? there will be no more questions thank you all for your advice thx
  3. #23
    The Superpro can't rotate once inserted. I wouldn't hammer one in, you'd damage the outer sleeve too much. The tool is the way to go IMO.
    I haven't changed the front bush but might in the future, it's the last thing that would allow toe changes during full power and heavy braking.
    I have ordered some powerflex bushes from PSItuning for this.
    I didn't resort to ratchet straps to get the wishbone back in, dead shot mallet and small tyre lever were the tools of choice.
  4. #24
    Sep 2006
    I will wait till you do yours before i put my ones in
    MODS- TOO MANY
  5. #25
    Quote Originally Posted by vwthunder View Post
    They will be here this week. Shipped on Friday
  6. #26
    Melbourne, Vic
    I don't get any squeaking what so ever, in my Polo with the Superpro bushes fitted. If you look at how they are fitted you will see why. Rotational movement, not twisting.
    Nah no squeeks at all, more so road noise and bumps, less give in movement = more vibrations transferred to the chassis
    I recon its my tires, done nearly 45,000 in the stock set, amazed they still even have tread
    2016 Golf R, APR Stage 1
    2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
  7. #27
    [QUOTE=h100vw;993130 I haven't changed the front bush but might in the future, it's the last thing that would allow toe changes during full power and heavy braking.
    Gavin[/QUOTE]
    Hey Gav, trying to get this right, could not find 1:Rear LCA bushes at PSI, so which make/brand part number and link to site is being recommended here, is it SuperPro?: 2:Are these the front LCA powerflex bushes from PSItuning? Powerflex Pack - PFF85-201 - Front Wishbone Front Bush - Polo 9N (2002 - 200 > Bushes > Suspension > Polo 9N 02-09 > VW Polo > VAG Specialists > PSI Tuning - VW Specialists
    I know, I don't not follow these posts etc very well, but am keen to get best rated front & back LCA bushes for mine! Cheers Al
  8. #28
    Coilovers with a rear sway IMO.
    Weitec [/B]for and whiteline for a good cheap solution.
    TPR Preeny has Weitec GT Hicons Coilovers at 25% off and you will not do better! and get in quick as it ends 30th September!
  9. #29
    Al, Superpro for the rear ones, GSLRallysport.
    I have a selection of Powerflex front ones coming. I'll probably just go with the soft ones, said no Gavin ever
  10. #30
    Thanks Gav. When you say 'selection' does mean you have brought excess Powerflex front ones to on sell to us punters? Cheers Al
