Those wheels look great mate, I too never knew that these came out in 4 door versions in other places around the world.
The stretch looks like a good measure to avoid strut clearance issues, great work.
Kelvnii those rims look hot! Those Oz rims sure look expensive. I really love how much wider they make the stance look. So no rubbing either? Thats good to know for future reference. I'd love to get some Oz rims myself at some stage.
I also got to say how wierd it is to see the GTI in a 4 door! Only thought it came in 3. Learn a new thing everyday as they say.
Mk3.Mk4.Mk1
My Mk1 Project
ya before me and the shop worrys about the rubber issue, but after he fits in the tyres in it just perfect! without any problems!
the rim size is 8x17 ET 35 and the rubber is 215/40 R17, but i think 205/40 R17 will be better if lower it, i'm still thinking get the eibach springs to lower 35mm, anyone have them fitted? and how its handle?did you change the dampers as well?
or get the Koni dampers with eibach springs?
check out the OZ website it shows the rim size for our polo 9N / 9N3
http://www.ozracing.com/at-team/whee...11.2001/-17/en
2013 4Motion "BLACK BEAR"
http://blackbeartiguan.blogspot.hk//
I'm not sure if the Eibachs go as low as 35mm. From the many threads on suspension it seems that the H&R springs are the springs of choice as they go bit lower. Could be mistaken but I think thats the story. Many have the H&R springs teamed up with Bilstein b8s. It is an awesome combination.
If you do lower it I think you will find that there will be some rubbing with the 215s but to tell you the truth, it looks pretty good as you have it now.
yes i guess 215 will be some rubbing, may be need to order 205 40 in the future
Those rims look hawwwttt man!!! CongratsEven if I am a little biased...
Were you in Perth before going back to HK- for some reason I thought you were a local hahah
'04 BMP MkIV R32 #144
search getnew
