Results 11 to 20 of 28
Thread: New 9n3 GTI owner
    nsw
    If you want to dotrack stuff then I'd go for the chassis mods first. You'll have more fun with agood handling car and a good handling car on good tyres is way quicker than astock chassis Polo with 300hp. The OEM brakes are actually fine at firstprovided you have decent pads and fluid so you'll be good there initially.
    The cars intrinsicshortcomings are that it has woeful bushes, terrible geometry and terribledamping. Bushings – just change them all. Geometry - you have insufficientfront caster and nearly no front neg camber and the front ride height needs tobe kept high if you don’t like positive camber through corners. At the rear ithas a workable amount of rear camber but the toe is out to lunch.
    If I was to have mytime again, and assuming that you’ll do suspension in a staged sort of way sothat each step doesn’t redo a previous one (the most budget conscious way) thenI’d do it like this:
    1. Rebush thewhole car including dogbone and rear beam. Get the rear LCA bushes that areoffset and set them in the max caster position. You already have anti roll barsso set them on soft at the front and hard at the back. Then get a set ofSpeciality Products/Eibach shims to shim the rear beams stub axles and correctfor its near 8mm toe in. No FWD car will hook into a corner with that much toein so shim it for 2mm toe out and maybe a touch of additional extra neg camberand right there the car will feel transformed. At the same time set the fronttotal toe at 2mm toe out. That’s about all you can do at this stage.
    2. Nextcommitment level is damping. Problem is damping requires a spring decision simultaneouslyusually and sometimes also a strut top decision, so here’s the bit where lotsof consideration comes into it. Depending on budget you can go for coilovers with adjustable tops (solvingspring/ damping and front geometry in one go) eg KW clubsport for off the shelf options thatinclude tops or you can use K-mac, ground control or suspension concepts topsand adapt them to the strut/coilover of your choice. Out of those I think onlyK-mac make adjustable tops that can go straight onto say Bilstein B8 damperswithout modification. You can gocoilover retaining your OEM tops and there gain the advantage of being able topick and choose the springs of your choice but keep in mind that oem stut topsare likely in need of a change anyway and you wont be solving the cars severelack of caster and camber at the front. Or you can retain stock springs andjust throw in a set of Bilstein B8 dampers. It’s a budgetary and intended usedecision. Let us know where you fit withwhat you’re prepared to spend on this step and we can advise you regarding bangfor buck, or optimal spring rates, or which strut tops to choose etc.
    3. This stepis kind of contingent on the one above. If you have adjustable tops then youmight already be happy with front geometry. If you want more though or you wantedto stay with OEM tops then you can find some geometry gain underneath the carif you inclined for a bit of engineer DIY. Fitting Audi RS TT balljoints to theOEM wishbones gives you roll centre correction and an additional degree of negcamber. You can also fit an eccentric bolt to the back of the subframe to allowyou to get a bit more caster. At this point if you’d stuck with factory springsyou could also find some springs for the rear that are lower and stiffer tooand really get its arse on the ground which will make it a lot more planted onfaster corners on the track.
    After all that the carwill be hooking and anywhere within that sequence if you were doing some trackstuff it’s a good idea to find some nice light track rims and get some R specsemi slicks. A good tyre size in legit R spec semis is 225/45/16. That’s areally common race tyre and allows you to buy second hand semis from race tyrecompanies eg Levens for cheap. Finding 16 inch x 7.5 in 5 x 100 PCD ET35-40 isthe hard and expensive bit. Allternatively you can find 15 inch x7 inchrims easy enough for 205/50/15 tyres. With the above suspension stuff onsomething like yokohma A050, Dunlop DZ03G, Toyo R888R or even Nankang AR-1’syou will be running rings around most guys at the track in your class.
    So next thing is enginepower. RE your exhaust question, put itthis way. Yes a continuous 2.75-3 inch system is the best – theoretically andin practice most of the time. YET, Ihad a custom code stage 1 tune, 3inch dump and 200 cell cat feeding into thestock back section where I’d just done a muffler delete and had fitted a parallelMBC to clip the overboost with that tune to 21psi and I have never had an enginethat has gone that hard. Since then I’ve had stage 2 generic tunes, customstage 2 tunes with bigger injectors and pumps, and now even have a K04-001turbo with the old APR tune and a full 3inch into 2.75inch system, and none ofthem can draw over 180g/s through the stock maf. The stage 1 tune on the stockback section exhaust and a bodge to prevent over boost made over 190g/s withnot a spec of timing pull. Go figure –that still has me baffled. The key isthe dump and cat. That’s the engine power equivalent of fitting a rear antiroll bar for handling. If you whack on a 3inch dump and 100 cell cat you are90% of the way there and that would work best with a stage 2 generic tune. Butat the end of the day after laying down the bucks on full exhaust systems andcustom tunes etc I reckon the car would be max 0.5sec quicker around southcircuit on engine power alone. The time (and fun) is all in the handling/tyresso I’d say put the dollars there initially and don’t obsess on power first.
    Oct 2017
    Wodonga, Vic
    ..... and an oil cooler, our cars have a water to oil heat exchanger - my car's temperature gauge would creep up after 2 laps at Winton and it'd cut power until I fitted an oil cooler, now no problems
    nsw
    I concur.
    May 2009
    Quote Originally Posted by simon k View Post
    dunno sorry, I've only had the one type, I went with what I found searching on here
    Thanks Simon, I got the 70K one - did a search on the forum and people are saying that the 70K one is enough and not too stiff for normal driving.
    May 2009
    Quote Originally Posted by sambb View Post
    If you want to dotrack stuff then I'd go for the chassis mods first. You'll have more fun with agood handling car and a good handling car on good tyres is way quicker than astock chassis Polo with 300hp. The OEM brakes are actually fine at firstprovided you have decent pads and fluid so you'll be good there initially.....
    Hi Sam,
    Thanks for taking the trouble to write such a comprehensive reply! It is much appreciated.
    I have just purchased all of the necessary Superpro bushes thanks to Simon's recommendation.
    I was considering doing the coilovers before the tune actually. I was thinking of getting Bilstein B16s with adjustable damping. I read that that KW coilovers and it's cheaper variants (ST coilovers) were hard to get parts for and re-built easily in Australia and that Bilsteins are much easier. My mechanic has suggested BC coilovers as budget alternatives.
    I have a bit of a crunch in the gearbox going between 3rd to 4th since my mechanic changed the transmission fluid for me so I will be going back on Tuesday to see if it needs a bit more fluid put in. Also getting a bit of hesitation on acceleration and have bought replacement PRV and hose as they are leaking otherwise, it might be caused by a dirty MAF.
    May 2009
    Thanks Simon - do you have a link or the brand and model of oil cooler to use?
    nsw
    I have a sceond hand oil cooler and mocal thermostated sandwich plate if you're interested
    nsw
    yep go bilstein over KW any day RE service. The car I bought has KW that are just paper weights because noone can fix them here. B16's will be sweet. Just need tops for them. See if K-mac still do them or suspension concepts might have something that'll fit.
    Oct 2017
    Wodonga, Vic
    Quote Originally Posted by triode12 View Post
    I copied what Sam did on his silver car, so the 2nd hand stuff he has is identical to what I'm using.. The only thing I'd do differently is use barb fittings and hose clamps instead of Aeroflow, that stuff was a pain and way too expensive
    nsw
    Yep I really don’t get the aftermarket automotive worlds obsession with -AN fittings. The top shelf stuff is probably perfect for task but the stuff that we mere mortals can afford seems to have the worst quality control. I’m not a F*&^tard yet simply have never had -AN fittings not leak. Aeroflow, superflow etc etc That’s including pushlock where the only way it can leak is at the seat or at the swivel joint (out of my control) yet it always weeps. That’s absurd to me given the really low oil pressures you see in cars. I work in industrial manufacturing and NONE of that stuff exists in the stupendous hydraulics we work with. Most of the time its just barbed brass fittings with compression clamps holding inside psi that would blow your head off if it let go and not a drop of oil in sight. Dunno but provided the Internal diameters of the fittings are sized correctly to allow the flow demands and not cause pressure drop and the hose you are using is temp and oil rated, I cant see why you shouldn’t save money with an oil cooler setup using brass fittings and proper clamps. Having said that I can pass onto you some used -AN fittings if you really wanted them that I had with the cooler but you’ll be cleaning up the mess at every oil change interval.
