Results 1 to 6 of 6
Thread: Neuspeed Cai
    Jun 2008
    I think the most important problem is there is no room to get a lot of cold air to the air intake rather then heat shield problem....
    S.E Melbourne
    aren't some people already running CAI? how did they get around that problem?
    Jun 2008
    Still wondering around this problem...
    I have got a 1.5 yaris before and with the cai around the fog light, i got 122g/s air going though, but apprantly other guys here with seat intake and K n N with chop only managed to get 133g/s (correct me if i remember wrong!)
    And the yaris is not turbo charged and dun have other mods to it...
    I also trying to fit or souce some sort of high flow intake system, but without sucess yet...
    I will let u know if i made any progress....
    Feb 2008
    Quote Originally Posted by Whubbsie View Post
    By using a smaller Odyssey battery which is about half the size of the stock item.
    Feb 2007
    Brisvegas
    Just remember... a golf IV has it's intake in the same position as ours, hence there would be no direct cold air feed in it's intended application.. You would need to check the mounting points are the same
    We did some testing on my old excel and found the best place to position a filter (or cold air intake) was directly behind the headlight as there is heaps of cold air available there..
    Maybe it's a case of installing a shielded pod filter such as this (with foam stripping on the top to seal against the bonnet) then run ~3" flexible piping from behdin the headlight into the shielded filter enclosure. An extra hold would need to be cut into the shild in order for this to work.
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
