Results 1 to 10 of 15
Thread: negative wheel offset
    nsw
    Is it true that the early polo gti's had a slightly different standard wheel offset to the later models? If so, anyone know which of the gti wheels had the greatest negative offset and what model years they were from?
    No 9n would have had had negative offsets regardless of width
    I think there was a change by about 5mm somewhere along the piece, but in any case they're still very 'positive'
    Cheap, Fast, Reliable. Choose two.
    nsw
    ok I thought they were near zero for some reason - and only 5mm difference - that sucks. Any ideas which model years had the wheels with the least positive offset then?thanks
    May 2011
    Albury, NSW
    Are you sure this is 9N and not 6R? 6R's added optioned wheels from Denvers to Detroits. - 9Ns stayed the same through production. The only way to find out is to get every 9N owner to post they're build date and offsets. I'm 2006 and I'm pretty sure ET43.
    2019 132TSI Tiguan
    2011 Audi S4 Wagon
    1988 MK1 Caddy
    2006 Polo GTI
    nsw
    no I'm certain of nothing. I just remember reading somewhere on here when people were discussing how gearbox changes were made throughout the model years and which years had the best boxes, that it was mentioned that wheel offsets had varied too. Can't find it again though.
    Jan 2009
    blankedy
    Get some 8" Enkei's, 35 is a nice stance.
    nsw
    ha ha. No I don't have the dosh for that. Just thought that if there was a fair amount more neg. offset to be had which could potentially benefit the steering, that someone might want to swap wheels for the wider stance ones. From the sound of it though its doubtful whether there is any offset variation anyway let alone a big enough one to be felt at the wheel.
    Nov 2008
    Canberra
    Quote Originally Posted by Stuwey View Post
    GTI - up to early 06 had ET 43, later 06 to 09 had ET 38. Best aftermarket wheels are ET 35.
    nsw
    sorry sorry. my shift worker brain gets muddy sometimes. When I was talking negative offsets what I meant to ask was which of the standard wheels offsets would give the most favourable scrub radius for ideal steering geometry (usually slight neg.). So you guys say that the ET35's are the best. Is that because it creates the closets thing to ideal scrub radius or because of aesthetics?
    thanks
