Results 11 to 20 of 32
Thread: Need Help ECU problem
    Jan 2009
    blankedy
    Simple check, remove your head unit, check cabling.
    Sep 2006
    Took the headunit out. Didn't make a difference. Doh
    Could it be a failing battery??
    Aug 2007
    Quote Originally Posted by vwthunder View Post
    Can check with VCDS mate, block 125
    Alba European
    Sep 2006
    Did a scan thanks to johnw, thanks for the use of the cable
    Oct 2009
    syd
    Get your battery tested. I had this same problem happen to me when I first bought my car, battery was dead, nothing would work but the engine still started. After I replaced the battery, got all the codes cleared, and it was all good.
    Regarding your engine codes, thats something else.
    You put a smaller battery in... And you've got a big stereo.... And you're having electrical faults...
    2+2=4.
    More electricity required. Thats why they have such big batteries standard.
    Cheap, Fast, Reliable. Choose two.
    Jan 2009
    blankedy
    Once the car is running it's the alternator that supplies power. Big stereo setups often have bigger alt's
    Sep 2006
    I am running 2 amps one for sub and another for front speakers, car seems to start better with new battery.
    It is not that small it is 450CCA which should be pretty good, I think standard is 500CCA or 550
    Stereo works and lights on etc when car is turned off, so i didnt think the battery was lacking power
    Yeah, but how many volts do you have???
    You'll need at LEAST 14.4 to keep these little tech-boxes running. Faulty battery or faulty connections are where i'd be looking.
    You have an electrical problem, which occured after you changed your battery system.
    Return it to standard and go from there...
