Results 1 to 10 of 13
Thread: N75F valve
    Jun 2007
    That's the issue - by pairing an upgraded N75 with a high boost ECU program you can hit "limp mode".
    The N75 version "J" is popular, and in some 1.8T applications, reacts in a very linear way throughout the RPM range and may not trigger "limp mode" as encountered with many 1.0 bar chip programs.
    This is why I'm curious to know whether it's been attempted on a Polo GTI.
    Polo runs an 058 906 283F valve - the only AUS delivered car that ran the "J" valve was the Audi 200T (circa 1982) - you can buy them new from your Audi dealer for about $120.
    I have only seen them tried on MKIV GTi's & A3's (DBC models) and although it picks up boost a little quicker, it ran a little flatter through the mid range.
    So it "felt" a little quicker, but was not actually, and maybe a touch slower through the mid range.
    Some one needs to spend the cash & data log it - I'll wage a carton of beer it will see no quantifiable gains on a dyno!
    P.S. Most software tuners frown apon it as they spend hours & hours tuning it for the valve supplied on the car! On a stage 3+ car (where we are hitting 28 - 30PSI) - the difference is so great, the wrong valve will send you into limp mode pretty quickly!
    Oct 2006
    thats interesting...
    from what ive been told those valves will start to leak or fail, if you have to change it, a j valve will generally give a better result, at worse the same as a new stock one.
    as for extra boost, variying results have been found, depending on other factors, on hard ware in the car and ecu tune itself
    theres a lot of this in the vortex in FAQ under the 1.8t forum and golf iv thread as well that says basically the same thing as i had a search and read as i was a little confused about 'why the hell do we change these valves for?'
    Quote Originally Posted by N75 info elsewhere
    H, higher spike than J, but holds less.
    K, I haven't really heard much, and what I've heard is conflicting, but it does hold more than the others.
    C, older stock valve, holds a bit more than F
    F, newer, smoother valve found in 1.8Ts
    Quote Originally Posted by vortex user
    Yeah stock turbo with APR software. I talked to the APR rep on here and he said to get an "H". Where Can I get one.
    Theres endless threads on VW Vortex from every ecu tuner and modifier around saying changing the valve is the go and of course varied results, some working better then other cars, or no difference at all on others dependant on mods, and tune.
    So im confused
    gpk_gti Guest
    I ran a dyno without the n75 race valve and then with it...gain was 1psi across the rev range.this was before my chip change.
    Jun 2007
    Quote Originally Posted by gpk_gti View Post
    when you say 'race' valve, you mean "j" valve right? ..was there a power difference on the dyno? (there could be a carton of grog coming your way)
    anyway, here's another perspective to perplex us even further:
    http://www.ozaudi.com/forums/showthread.php?t=1308
    I'm following this thread very closely as I've been thinking about it also for a while just because I have got nothing else to spend money on.
    I've heard mixed reports so untill I see some conclusive evidence - I'll stay with my current one I thinks.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    That old ozaudi post pretty much sums it up (whoever did that testing back in 2004!)
    Its good to have actual data to back it up instead of dozens of people who says it "feels better" - It probably feels better because their wallet is lighter!
    That data shows it won't hold boost as long as the H valve.
    http://forums.vwvortex.com/zerothread?id=1150353
    http://forums.vwvortex.com/zerothread?id=1340173
    http://forums.vwvortex.com/zerothread?id=1124714
    These were done in Australia
    Nov 2006
    Struth! That's upping the ante. I thought I was the resident cynic, but I've never waged beer!
