yeah running the fan constantly wont hurt. Those small fans can be pretty intrusive with the noise though but by the sound of it you wont be hearing it over the exhaust anyway.
I forgot you said you were running de-cat so I understand it must be really popping and banging for sure.
Ok so from what you are saying the cat back + dump is markedly more powerful than standard back section + dump. And from what you are saying the difference is felt from boost onset all the way through, not just up top. Correct?
PS - yep your gauge is cactus. Plumbed to the plenum with a proper reducer tee piece is the way to go. But yeah 50psi is impossible. It just cant push that much air and back pressure in the exhaust will stop it going much above 30 psi anyway.
