Originally Posted by
sambb
oh and RE the vcds stuff, block 031 should be updating constantly even at cold start. Block 032 though will only start showing STFT trim changes when the cold start/warm start routine finishes I think. Its long term fuel trim LTFT usually needs the coolant temp to be greater than 75 degrees + some other conditions before you'll see it appear and getting it to update can take sometimes a long drive in cruise mode ie closed loop. If your block 032 trims dont eventually appear/update, let yus know cos there's a couple of simple things that can cause that other than say a dud 02 sensor.
You could also monito block 091 I think it is - it'll say 0.00 or 20.0 degrees cf. That shows inlet cam advance. It advances to 20cf = 20 crank degrees only at cold start up. If its not doing that then you might have a weird cold start because the cam is all over the place due to a dud chain tensioner or the cam advance solenoid isnt moving the cam.
