Results 1 to 6 of 6
Thread: Meow (replace the Cat)
noone Meow (replace the Cat) 14-08-2012, 05:47 PM
clicht The 200 cell is perfect,and... 14-08-2012, 06:31 PM
s4mmie You'll def need to offset the... 14-08-2012, 08:42 PM
noone Any benefit or loss in going... 14-08-2012, 11:06 PM
insanekiwi Since you have 2.5 go with... 16-08-2012, 07:14 AM
noone Thanks mate. 16-08-2012, 08:53 AM
    Jan 2009
    blankedy
    Looking to replace my Cat.
    Thinking of supporting local, but going for a quality brand.
    Magnaflow 2.5 200 cell? Any reason not to go down this path?
    Greg @ Carformance sells them: Magnaflow 2.5" High-Flow Catalytic cat Converter
    Looking for an o2 spacer as well, have been advised to get one with an angle to it so its not going to conflict with other guff down there...
    Jan 2012
    Bentleigh East, Melbourne, Vic
    The 200 cell is perfect,and magnaflow is very decent.
    Just a heads up, even with an o2 spacer, there is a chance that the cel comes on after some km's
    Polo 9n3 GTI
    You'll def need to offset the O2 sensor, mine is pretty close to the tunnel even on an angle...
    Can't remember, do you have a tune? Not sure on the others but APR tune, no CEL.
    Jan 2009
    blankedy
    Any benefit or loss in going 2.25 or 3 inch design? Would a zorst shop still be able to work with the Chang over easily enough?
    Stock exhaust with 2.5 dump already...
    Jul 2007
    Auckland, NZ
    Since you have 2.5 go with the same size. Even with my 3" dp, I would go down to 2.5 and keep it 2.5 through out. This likely will give you the best of balanced torque and power. My decat GTI smells and I probably will go down this route in the future. Mine is revo stage 2 and with decat and sensor in place, no problem with CEL as I believe it's deleted from sensor point of view.
    06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
    06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
    Jan 2009
    blankedy
    Thanks mate.
