Page 25 of 58 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 580
Thread: Meet my Polo!
  1. #241
    Dec 2008
    Curitiba/PR, Brazil
    Plautos,
    I thought I remembered reading something about you modifying your shock absorbers, but cant seem to locate it.
    Are you still on the stock shocks? Did you modify them?
    The stock shocks from the Polo GTI still intact.
    I had modified a Polo 2.0 front shock, I remove the internals and inserted a Koni's shock.
    SILVER TEAM
  2. #242
    Jan 2009
    blankedy
    Quote Originally Posted by Plautos View Post
    Reading here in the forum, I learned that the Waste Gate actuator is very soft, so I thought in block the air flow to it. Is when I installed an industrial Festo’s air flow controller. The results were impressive. The boost stay fixed, I could completely block the air to the N75 valve and the turbo still loose boost at hi rpm’s, keeping it safe, proving it is a soft WG actuator.
    Can anyone comment on if the wastegate actuator problem / limitation would be fixed by replacing the diverter valve with an aftermarket unit (Forge / APR)?
    Not sure of the relationship here here.
  3. #243
    Nov 2008
    Killara Sydney
    Waste gate and diverter valve are two different things. The diverter operates off throttle the N75 is what controls the waste gate for on boost aplications.
    Joe Chu
  4. #244
    Jan 2009
    blankedy
    Quote Originally Posted by Joe Chu View Post
    Waste gate and diverter valve are two different things. The diverter operates off throttle the N75 is what controls the waste gate for on boost applications.
    Thanks Joe, I'm thinking the N75J valve is probably a good investment.
    Is the Festo pressure regulator or something similar worth while for stock Turbo? Can anyone tell me what I'm looking for exactly? I've been poking around the Festo website, lots of products, not sure exactly what specs would suit. They do have a branch in Vic, but I really don't know if its worth my time with my basic mods...
  5. #245
    Dec 2008
    Curitiba/PR, Brazil
    Finally the bars arrived.
    I installed the rear one today, next week I’m going to the front one.
    I need to fabricate spacers because the U-bolts are over sized, the threads were not long enough to do a good tight.
    SILVER TEAM
  6. #246
    Feb 2007
    Brisvegas
    Yeah Whiteline have done this a few times before and sent the wrong bolts with the sway bar. Send them an email mate and the should send you the correct ones!
    BTW how is the new Garrett turbo coming along
  7. #247
    S.E Melbourne
    haha love it Plautos you have this monster of a track polo thats only just now getting swaybars.
    Make me want to ship mine to Brazil so I can get you to make mine a carbon copy in black.
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
  8. #248
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by VWindahouse View Post
    I'm developing a new actuator for the WG, something softer. I'm not going to use the N75 to control the turbo.
    In the next week I will start the manufacture of the exhaust manifold.
    SILVER TEAM
  9. #249
    Dec 2008
    Curitiba/PR, Brazil
    SILVER TEAM
  10. #250
    Jan 2009
    Plautos, I'd be interested to get your feedback on how you find having done just the rear and than adding the front. Was the front an obvious improvement, having done the rear, or to keep it balanced, etc.
    I do understand how and why they work, just curious for your reasoning for doing both.
