Page 13 of 58 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 580
Thread: Meet my Polo!
  1. #121
    May 2007
    Burleigh Heads, Qld
    Personally, I liked the playing of Black Sabbath and then Pearl Jam in the background until road/motor noise took over
  2. #122
    Nov 2008
    Wembley, WA
    Quote Originally Posted by Plautos View Post
    In the beginning making turns with the second gear was very hard, I was loosing traction, the car was over steering, but the track have a good grip, so I had to adjust me to the problem. I had to control more the throttle, pumping it or going slower.
    I don’t know the car 100% yet. I need to practice more. Fix some suspension and brake issues.
    But in the end, traction is not a problem, the car have a good grip after all.
    Yeah I just checked out the vid and it performs awesomely and you don;t seem to be having any grip issues at all. I love that track. Looks awesome and very fast. What sort of top speeds can you get upto on that? Looked pretty fast to me.
  3. #123
    Dec 2008
    Curitiba/PR, Brazil
    http://user.streetfire.net/video/Tra...gos_636700.htm
    My top speed was 210km/h at 110m to the first leg of the S.
    Hit the brakes, go to 80km/h to make the turn.
    SILVER TEAM
  4. #124
    Dec 2008
    Curitiba/PR, Brazil
    This is very interesting.
    http://www.youtube.com/watch?v=WJaZ4yLCTeg
    SILVER TEAM
  5. #125
    Dec 2008
    Curitiba/PR, Brazil
    SILVER TEAM
  6. #126
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by insanekiwi View Post
    Wow... impressive... very very.
    Can you please put your mod-list again with uptodate info?
    Oh yeah and the videos were cool, but human camera mount gave me motion sickness
    Ok.. Just to clear everyone thoughts..
    Engine:
    Hi flow exhaust manifold,
    RS4 CHRA turbo, K04-25, mounted in a machined K04-01 compressor housing.
    Forge FMIC and TIP,
    K&N 3004 air filter,
    N75Race,
    0280156063 fuel injectors TT225,
    NGK spark plugs PFR7Q,
    Moroso crankcase evacuation system.
    Exhaust:
    3”Downpipe to the Stock catalyst,
    2,5”Catalyst to the end.
    Suspension:
    H&R Springs
    Wheels:
    Center Line, Storm. Light weight 18x7
    Tires:
    Yokohama Parada 215x35 R18
    Brakes:
    Wilwood Forged Superlite 4 pistons;
    14”Rotors;
    Eletronics:
    APR k04 software.
    I’m running with 95oct fuel.
    These infos I found on the net when I was researching turbos. I don’t know how precise they are, but I know they are very close.
    The Turbos.
    Their specs are as follows as compared to a regular RS4 K04.
    compressor wheel RS4: 40mm inducer, 51mm exducer
    compressor wheel RS6: 42mm inducer, 56mm exducer
    K03
    That turbo had a compressor wheel with the following dimensions:
    Inducer: 33.6mm
    Exducer: 46mm
    Tip height: 3.7mm
    The K04-001 compressor looks like this:
    Inducer: 35mm
    Exducer: 50mm
    Tip height: 3.7mm
    The K03-052 (K03S) compressor is a bit larger still:
    Inducer: 38mm
    Exducer: 51mm
    Tip height: 4.4mm
    The K03S is saddled with a tiny turbine:
    Inducer: 45mm
    Exducer: 38mm
    Tip height: 6.8mm
    Blades: 11
    compared to the K04 turbine:
    Inducer: 50mm
    Exducer: 42mm
    Tip height: 6.4mm
    Blades: 11 => MY k04-25 TURBO HAS 12 BLADES!!!
    SILVER TEAM
  7. #127
    Dec 2008
    Curitiba/PR, Brazil
    Pizza anyone?
    Only one damaged rotor, front left.
    SILVER TEAM
  8. #128
    Nov 2008
    Wembley, WA
    Geez how did you manage that! Looks a bit nasty. Defective rotor?
  9. #129
    Jan 2009
    sunshine coast
    awsome pics man. those rotors covered/under waranty?
  10. #130
    Mar 2008
    Wow how does a rotor like that brake? That's crazy!
