Page 3 of 58 FirstFirst 123451353 ... LastLast
Results 21 to 30 of 580
Thread: Meet my Polo!
  1. #21
    Feb 2008
    Quote Originally Posted by Buller_Scott View Post
    Not to mention eliminating the ram-air effect of the stock intake mouth and air box......
    This would have more of an effect if the car was N/A. As the car is forced induction, this has little or no effect in the grand scheme of things.
  2. #22
    melbourne
    Quote Originally Posted by Blitzen View Post
    Really? Call me clueless, but at tdiclub.com, its all about ram air...
  3. #23
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by JCM308 View Post
    I remember reading that boost controllers do not work on the Polo's. How does this air flow controller work as from what I understand it restricts air to the Actuator. This is what boost controllers also do so how does one thing work and not the other??? (sorry if this seems a little off topic but I'm interested in the answer).
    I think the boost controller can’t block the air completely to the WG actuator.
    I have a HKS boost controller in other car, in the manual it says 1,5bar is its maximum pressure. However this industrial valve can hold 10bar.
    SILVER TEAM
  4. #24
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by Jmac View Post
    Correct me if im wrong, but if you control the air to N75 which is the boost controller, then you really are still doing the same job as a manual boost controller, but only it will be smoother correct?????? Looks like you are restricting the input to N75 and then of course this will alter the output from N75 so i can see how it could be smoother as the ecu still drives N75.
    Hmm
    Yes! That's it!
    SILVER TEAM
  5. #25
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by shaneth View Post
    Funnily enough i have been talking to a mate about this exact same thing as well. He said if you put one of these valves in it restricts the boost from getting to the wastegate until a set limit. So if the wastegate is bleeding off early, the valve wont let the air get to the wastegate. which means more boost longer. but does this have an effect on AFR, and the boost requested and actual boost??
    Please correct me if im wrong....
    Yes it affects the AFR, but the electronics can handle. The MAF is reading more air flow and the Lambda meter is correcting the fuel mixture.
    The electronics will try to protect the engine is something is wrong.
    After 1,6bar that vacuum box over the engine is opening my BOV, holding the pressure at 1,3bar. So I pump the throttle and the full boost come again.
    SILVER TEAM
  6. #26
    Dec 2008
    Curitiba/PR, Brazil
    This is two in one dynameters runs.
    The blue run is with the car chipped, only with the air filter.
    Look the Roller Coaster, that is the WG opening and closing.
    The red one is with the exhaust done, N75 race and the Festo valve.
    At the dynamometer it shows the loss of the peak power, however I didn’t felt it when driving the car.
    Power agaist torque.
    SILVER TEAM
  7. #27
    Jan 2008
    Quote Originally Posted by Plautos Cattalini Lins View Post
    The next day I install a Moroso breather valve, the engine fumes and oil vapors they are not going to the TIP anymore, now they are going to the exhaust. No more oil to the intercooler.
    Today I change the rims, I installed a set of Center Line’s Storm wheels. They are 18x7. I’m using Yokohama Parada 215/35.
    You sure this works?
    Intake pipe has a vacuum affect as it draws air in it also draws oil vapor form the crankcase. The exhaust on the other hand has pressure in it, which in turn would pressurise your crank case.
    I have never seen a kit like it before maybe you can tell me how it works.
  8. #28
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by Bubu View Post
    The golden piece is a one way valve. It opens only with positive pressure inside the engine, so exhaust gases cannot come back thru it.
    We have pressure at exhaust manifold, not after the turbo.
    http://store.summitracing.com/partde...5&autoview=sku
    At the end you can see the instruction manual.
    SILVER TEAM
  9. #29
    Dec 2008
    Curitiba/PR, Brazil
    The intercooler arrived today.
    Very good product.
    SILVER TEAM
  10. #30
    Dec 2008
    Curitiba/PR, Brazil
    This is what is happening..
    SILVER TEAM
