Page 2 of 58 FirstFirst 12341252 ... LastLast
Results 11 to 20 of 580
Thread: Meet my Polo!
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by [-Polo GTI-] View Post
    yeah i agree. the intake hose does run to the filter between the battery and the engine to get sufficient cold air but there does need to be some sort of heat shield put between the pod and engine.
    Let the intercooler do his job!
    I remove all the sealing rubber from the engine compartment, the air is flowing much more freely now.
    SILVER TEAM
    Aug 2006
    what does it do for performance tho?? or wot effects does it give?
    Dec 2008
    Curitiba/PR, Brazil
    Quote Originally Posted by BL33SU View Post
    Your car is chipped?
    It will hold higher boost during more time.
    SILVER TEAM
    Aug 2006
    Quote Originally Posted by Plautos Cattalini Lins View Post
    yeh it is.. hold higher boost
    how much did that controller cost u?
    which valve is it?
    https://enep.festo.com/irj/servlet/p...ep_customer_au
    Dec 2008
    Curitiba/PR, Brazil
    which valve is it?
    GR-1/8-B
    Valves=>Flow control Valves=>One way control Valves=>In line Instalation GR
    Here it cost around $50,00. I don't know..
    You will need a pair of nipples.
    SILVER TEAM
    Aug 2008
    I remember reading that boost controllers do not work on the Polo's. How does this air flow controller work as from what I understand it restricts air to the Actuator. This is what boost controllers also do so how does one thing work and not the other??? (sorry if this seems a little off topic but I'm interested in the answer).
    Cheers,
    John
    Jan 2008
    Interesting.
    Aug 2007
    Correct me if im wrong, but if you control the air to N75 which is the boost controller, then you really are still doing the same job as a manual boost controller, but only it will be smoother correct?????? Looks like you are restricting the input to N75 and then of course this will alter the output from N75 so i can see how it could be smoother as the ecu still drives N75.
    Hmm
    Alba European
    Sep 2006
    Brisvegas
    Funnily enough i have been talking to a mate about this exact same thing as well. He said if you put one of these valves in it restricts the boost from getting to the wastegate until a set limit. So if the wastegate is bleeding off early, the valve wont let the air get to the wastegate. which means more boost longer. but does this have an effect on AFR, and the boost requested and actual boost??
    Please correct me if im wrong....
    For Sale 2006 VW Polo GTI
    Have a Look
    CUSTOM CODE
    Phase 2
    melbourne
    Quote Originally Posted by marko View Post
    Looks good!
    Although I reckon that unprotected pod filter will be hurting your performance quite a bit. Possibly more than the stock air intake. Those things really suffer from heatsoak when they are just sitting open in the engine bay.
    Not to mention eliminating the ram-air effect of the stock intake mouth and air box......
