Page 47 of 58 FirstFirst ... 37454647484957 ... LastLast
Results 461 to 470 of 580
Thread: Meet my Polo!
  1. #461
    Dec 2008
    Curitiba/PR, Brazil
    thatīs the idea...
    SILVER TEAM
  2. #462
    May 2009
    S.E. Melb Vic
    WOW, my only concern would be the front pillar, the b pillar and the curtain air bags. Have you designed the cage to clear them or are you going to disable them.
  3. #463
    Jul 2010
    I'd be so interested on how the handling feels after installing something like that into a Polo.
    MY2008 VW Polo GTi / GIAC Tune / Forge FMIC / Forge 007 DV / N75 Race / BMC OTA / KW V1 Coilovers / Whiteline Front&Rear Swaybars + Toe-In Shim / Weichers Front&Rear Strut Braces / Full Non-Res Milltek Exhaust / 17" Bora Sport
  4. #464
    Feb 2007
    Brisvegas
    If you are serious about going a full cage, make sure at the front you tie the towers to the dash hoop / cowl...
    '06 Polo GTi - Candy White / Custom Leather / Looking for Dish!!!
  5. #465
    Dec 2008
    Curitiba/PR, Brazil
    Air bags are dead weight... they stay out… stock seats also.
    Iīm impressed with the rear seat weight, it is very heavy… the car lifted 2 or 3 cm without the stock interior.
    Quote Originally Posted by ssman View Post
    SILVER TEAM
  6. #466
    Dec 2008
    Curitiba/PR, Brazil
    Iīm eating my fingers… I fear that the results may be not compatible with the project… the car is already very stiff… I donīt know if Iīm waiting for a miracle…
    Quote Originally Posted by kangfu View Post
    SILVER TEAM
  7. #467
    Dec 2008
    Curitiba/PR, Brazil
    Do you mean get through the fire wall? I thought about doing that… but it is very difficult… I will do a reinforced front strut bar…
    Quote Originally Posted by Spec83 View Post
    SILVER TEAM
  8. #468
    Dec 2008
    Curitiba/PR, Brazil
    Sneak peek...
    SILVER TEAM
  9. #469
    Quote Originally Posted by Plautos View Post
    thatīs the idea...
    There are a few issues with that cage. The side intrusion bars come up to high. They should be kept below the half way height of the cage.
    You should also triangulate the rear arms from the struts down to the bottom of the main hoop. A cross brace on the main hoop is also a good idea. Also I am really not sure what you are trying to do with the front legs.
    Also you shouldn't really need the harness bar with the cage if you have the cross brace you can simply run a couple of bars across from the diagonal to the sides of the main hoops for the harness mount.
    Also just noticed you are bending the main hoop backwards which is a no go.
    2008 VW Polo TDi
    GIAC | REMSA | PD160 | DECAT | MUFFLERECTOMY | ECS | SUPERPRO | PXL KIWI WIFI | 312mm BRAKES | OZ RACING | KUMHO V70A
    To Buy: VNT 17/22 or K3 Turbo | R783 Nozzles | Intercooler | Water meth kit.
  10. #470
    Dec 2008
    Curitiba/PR, Brazil
    SILVER TEAM
