Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 580
Thread: Meet my Polo!
Plautos Meet my Polo! 29-01-2009, 08:26 AM
Plautos http://img264.imageshack.us/im... 29-01-2009, 08:27 AM
Plautos My future ideas are a FMIC,... 29-01-2009, 08:37 AM
Plautos My next challenge will be the... 29-01-2009, 08:40 AM
RhysQ looks awesome now with those... 29-01-2009, 08:37 AM
Plautos Yes... Thoses guys are my... 29-01-2009, 08:42 AM
BL33SU where do u buy that air flow... 29-01-2009, 09:03 AM
JCM308 I remember reading that boost... 29-01-2009, 08:58 PM
Plautos I think the boost controller... 30-01-2009, 12:53 AM
Bubu You sure this works? ... 30-01-2009, 07:12 AM
Plautos The golden piece is a one way... 30-01-2009, 10:59 AM
Plautos The intercooler arrived... 03-02-2009, 12:50 AM
Plautos This is what is happening.. ... 03-02-2009, 07:10 AM
noone Can anyone comment on if the... 09-08-2009, 02:00 PM
Joe Chu Waste gate and diverter valve... 09-08-2009, 05:27 PM
noone Thanks Joe, I'm thinking the... 09-08-2009, 05:51 PM
Plautos Finally the bars arrived. I... 15-08-2009, 06:49 AM
noone Thanks. So what do the... 22-12-2010, 04:17 PM
Guy_H The flow charts are the most... 22-12-2010, 04:55 PM
noone So what does it mean? What is... 22-12-2010, 05:04 PM
gjuu and another question is...... 22-12-2010, 05:14 PM
Guy_H What it boils down to is... 22-12-2010, 05:27 PM
Tim you can see just by looking... 22-12-2010, 05:29 PM
Guy_H Actually Julian Edgar who is... 22-12-2010, 05:35 PM
Guy_H Just had a couple of beers... 22-12-2010, 06:05 PM
Cookie28 Love the seat mate looks... 14-08-2011, 10:19 AM
AusScare Agree on the seats, they look... 14-08-2011, 04:05 PM
noone That new tank location should... 18-04-2012, 02:21 PM
noone I think if you ever became... 21-07-2012, 10:18 AM
clicht This is looking brilliant... 21-07-2012, 11:13 AM
jasn78 Agree with noone but would... 21-07-2012, 11:56 AM
Plautos Thanks guys, I´m glad you´re... 24-07-2012, 07:31 AM
Plautos Here we go! ... 24-08-2012, 04:33 AM
Jmac Man you got some serious... 24-08-2012, 06:01 AM
leitch Yeah ditto. This keeps... 24-08-2012, 06:16 AM
9n3 Turbo Been following this thread... 08-02-2013, 12:20 AM
Plautos Sorry about the delay... the... 26-07-2013, 12:55 AM
sam_vw Meet my Polo! 26-07-2013, 05:31 AM
jasn78 Ok I just wet myself. that is... 26-07-2013, 11:18 AM
vwthunder Long time no update, awesome... 26-07-2013, 03:17 PM
Plautos testing!! Polo GTI,... 04-09-2013, 12:11 AM
Plautos Finally, the pics I was owing... 08-01-2014, 11:17 PM
noone It looks quite factory again... 09-01-2014, 07:24 AM
Plautos The car is awesome, the... 09-01-2014, 09:14 AM
Eddy Hoyhoy. I like very much,... 09-01-2014, 08:05 PM
Plautos hahaha Don´t worry about it!... 26-05-2014, 10:58 AM
Plautos new vídeos! ... 26-05-2014, 10:52 AM
    Feb 2007
    Brisvegas
    Yeah Whiteline have done this a few times before and sent the wrong bolts with the sway bar. Send them an email mate and the should send you the correct ones!
    BTW how is the new Garrett turbo coming along
    Jan 2009
    blankedy
    Thanks.
    So what do the numers mean and what specific info is there on the vehicles on the Dyno?
    I don't doubt the data, just need to be able to understand it...
    The flow charts are the most important, as you can see the stock one flows more than the unit in question, and the APR one flows, well you can see how it flows.
    The dyno plots are three different cars, but the ones to look at are the blue & the red lines.
    These are two K04 cars, both running downpipes (one with a catback), both running standard airboxes & the exact same software.
    The big difference is one runs the APR intercooler (BLUE) It could make 24PSI & hold a good boost curve.
    The Red line has the Forge intercooler & could only make 22psi, but the curve dropped off hard as you can see.
    The green line is a well worked K03 car that goes well.
    We have data logging from both the Blue car & the red car & it shows exactly the same, with the Forge intercooler on board, it can not make its requested boost, nor can it maintain a solid curve through a power run.
    James is trying to find the dyno's of the red car once the intercooler was swapped and how now the boost curve is the same as the red car.
    Jan 2009
    blankedy
    So what does it mean? What is the unit of measurement? I googled it, but could not find other flow testing or comparisons with PSI / Bar.
    I guess what I need to understand is what makes this example accurate for the Polo vs preferable for your product? If you tested at 25 Psi, then it's not really relevant as we don't make that much boost.
    Dec 2008
    Townsville FNQ
    Does this mean that you think better flow but higher intake temperatures (std vs forge) are more desirable than cooler intake temps and less airflow.
    (were the tests done after a good fang around the block to get that heat soak happening?)
    What it boils down to is power loss, which ever the way you look at it, due to inefficient intercooling & poor flow. As I mentioned earlier, the tests were on behalf of some customers that had the exact same issue.
    Going back several years (years before the Forge unit was on the market), we need an intercooler for our Tarmac Rally Polo 9N, we approached Richard at ARE ARE Cooling (Aluminium Radiators & Engineering P/L) - their reputation is second to none. Anyway, we had 2 choices, build a completely new core or modify the existing APR 1.8T specific intercooler to suit. Richard carried out flow testing & analysis on the APR core & it was deemed "More than adequate" - we also have APR's pressure drop figures through the core (air supply to the radiator) so there was zero danger of overheating. Anyway, it was expensive, but they worked.
    Don't take my word for it, feel free to have a stock vs any after-market version rested by any intercooler manufacturer with a flow bench - the results speak for themselves, as does the data logs & the dyno wheel readings & PSI drop.
    Point Cook, Vic
    you can see just by looking at the designs why the forge unit wouldnt flow as well. Doesnt look like they have put a lot of thought into it beyond getting as much cooling as possible.
    FOLLOW US ON FACEBOOK
    Actually Julian Edgar who is now a forum member (resides mostly in the Skoda section) may be able to comment further - he is a writer for Autospeed. A while ago (2003) they did a test on JDM intercooler (lots of them) using flow bench & volumetric measurements (mass also). Might be good for Autospeed to test several units side by side?
    AUTOSPEED LINK
    AUTOSPEED LINK
    Anyway, you should be able to gain a lot of information from those sites, as well as ARE's.
    Just had a couple of beers with an Auto engineer friend of mine - we were discussing this thread. He also mentioned a well known fact that for every 5 PSI extra a turbo has to make, it will increase heat by 13 - 17 degrees C.
    4. Its worth noting here that the MAP sensor is POST intercooler on the Polo - so any loss of boost pressure will be taken into account by the ECU; it will work the turbo harder to get the programmed boost. This will result in more overall air. I would have thought a tuner would understand that fact.
    So working the turbo harder will create more heat, the purpose of intercooling is to reduce intake heat & hopefully not working the turbocharger harder.
    Oct 2010
    Melbourne, VIC
    You've taken that quote out of it's original context. Xtturbo was saying that the boost fell because of the superior cooling provided by his IC (while the mass of air flowed stayed constant) so by running the turbo harder to get the same level of boost, you would end up with a greater mass of air flowed to the cylinders => more power.
    Now I'm not saying the Forge is better (or worse, for that matter) but the way you have cherry picked the quote makes it seem like xtturbo is just saying that the turbo will just force more air through to counteract the restriction of the IC
