Personally, I liked the playing of Black Sabbath and then Pearl Jam in the background until road/motor noise took over![]()
http://user.streetfire.net/video/Tra...gos_636700.htm
My top speed was 210km/h at 110m to the first leg of the S.
Hit the brakes, go to 80km/h to make the turn.
This is very interesting.
http://www.youtube.com/watch?v=WJaZ4yLCTeg
Ok.. Just to clear everyone thoughts..
Engine:
Hi flow exhaust manifold,
RS4 CHRA turbo, K04-25, mounted in a machined K04-01 compressor housing.
Forge FMIC and TIP,
K&N 3004 air filter,
N75Race,
0280156063 fuel injectors TT225,
NGK spark plugs PFR7Q,
Moroso crankcase evacuation system.
Exhaust:
3”Downpipe to the Stock catalyst,
2,5”Catalyst to the end.
Suspension:
H&R Springs
Wheels:
Center Line, Storm. Light weight 18x7
Tires:
Yokohama Parada 215x35 R18
Brakes:
Wilwood Forged Superlite 4 pistons;
14”Rotors;
Eletronics:
APR k04 software.
I’m running with 95oct fuel.
These infos I found on the net when I was researching turbos. I don’t know how precise they are, but I know they are very close.
The Turbos.
Their specs are as follows as compared to a regular RS4 K04.
compressor wheel RS4: 40mm inducer, 51mm exducer
compressor wheel RS6: 42mm inducer, 56mm exducer
K03
That turbo had a compressor wheel with the following dimensions:
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
The K04-001 compressor looks like this:
Inducer: 35mm
Exducer: 50mm
Tip height: 3.7mm
The K03-052 (K03S) compressor is a bit larger still:
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
The K03S is saddled with a tiny turbine:
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
compared to the K04 turbine:
Inducer: 50mm
Exducer: 42mm
Tip height: 6.4mm
Blades: 11 => MY k04-25 TURBO HAS 12 BLADES!!!
Geez how did you manage that! Looks a bit nasty. Defective rotor?
awsome pics man. those rotors covered/under waranty?
Wow how does a rotor like that brake? That's crazy!
