Results 1 to 10 of 15
Thread: Strange Boost Issues
    Jun 2016
    Duncraig, Perth
    Well where do I start. First of all, got a stage 1 code from Gavin Custom Code a few months ago. Car pulls well enough when the boost works.
    So this morning (months after the ECU flash) I quickly installed a boost gauge. Started the car from cold, warmed it up to find that it boosts to 17psi dropping off to 15psi as it gets closer to the redline (stock turbo running out of puff for the engine me thinks).
    Now the inherent problem I have had since day 1 I think.
    If I drive the car for a period of time say greater than 10 minutes and park up for a while, say again greater than 10 mins. The car has no power after this. So today with the boost gauge I confirmed that this is the case with a lowly 4psi of boost (limp home mode equivalent).
    Now when I first got the car there was a fault code on it relating to the N75 and the garage said that it was boosting to 9psi after resetting it (stock tune).
    Right, so potentially faulty N75.
    From there I disconnected the top hose (take the N75 out of the equation) and boosted to 17psi. I did quite a few 3rd and 4th gears runs getting braver to see where the boost would build to and never ever went over 17psi. Even with pretty hard presses on the accelerator for 5 seconds or more.
    So first things first, would I be right in saying that the N75 is sticking or possibly going out of resistance spec when heat soaked with the car stopped.
    Secondly, I think I must have something in the boost circuit limiting boost pressure as it never spiked above 17psi with the N75 disconnected.
    Now, to take the N75 (delete) out of the circuit is it the right thing to just install a manual boost controller and set the relief to say 18psi for example and the ECU tune / remap will take care of everything else as long as I keep the N75 connected to the wiring harness.
    Peregian Beach
    I remember with mine one of the two wires going to the N75 broke and obviously it went into limp mode as you suggest. However when it first started it would do it intermittently until eventually it broke completely. I surmised that it must touched enough sometimes and then other times it wouldn't. When I googled the fault code I found that it was apparently a fairly common problem. The wires are very thin. Just putting it out there as a possible reason. We simply resoldered the wire and it has been all good since.
    It will be far better to fix the N75 issue. VW spent a small fortune developing the ECU with Bosch, it would be a big shame to bypass their efforts.
    When the N75 fails, the turbo will run at actuator pressure. 9PSI is a bit high for that and 4 seems really low. Although I would prefer to see what the ECU is seeing as requested and actual boost. Using VCDS
    When the N75 fails electrically, it will run the turbo at actuator pressure.
    If something else was wrong the symptoms would be different I feel.
    If you're handy with a multimeter, there's a few things I can talk you through to investigate.
    You have my number?
    Jun 2016
    Duncraig, Perth
    Hi Gav,
    It's really weird. When starting from cold there is no issues. Only when the engine has been stopped for 10 mins plus and had a chance to heat soak then it becomes an issue.
    If you don't stop the car its fine for as long as you drive it. Just drove an hour and no issues. Checking boost all the way home and peaking at 17psi and dropping off to 15psi.
    Just about to eat, if I went out in 10 mins or so, 4 psi would be all I would get. Leave it for an hour and back to full boost. Has me stumped hence why I was thinking a sticky waste gate or N75.
    Unfortunately no VCDS available without paying 150 bucks WA rate for a quick scan. Wish I could find a reasonably cheap hand held diagnostic tool without going down the Ross tech route as I have no windows based PC's/laptops in the house anymore. We are all Mac / ipads now.
    Mac, pffft. �� Anything with XP would be OK. Cheap eBay cable and a proper license for 99usd.
    Jan 2009
    The intermittent fault you've described sounds exactly how my n75 died. Take off at lights with boost, next set of lights, nothing. Can you borrow an n75 from another member for the day to validate?
    You mentioned you had disconnected "pipes" to check. You should just pull the electronic connector from the n75, leave all pipes in place. That'll give somewhere around 4-7psi. If you pull the vacuum line that runs onto the wastegate, that'll boost ~25psi. I wouldn't recommend this later approach.
    nsw
    in the mean time plumb everything back up, reseat the N75 plug with some CRC to clean the terminals and while you're at it check that the N75 plug wires look ok ( no cracks, creases or breaks). It does sound like an N75 issue. When the N75 open circuits the peak boost will drop to actuator pressure. That you are getting only 4psi at that stage sounds like you may possibly have a turd actuator ie rod tension too slack and holding the flapper open?
    Jun 2016
    Duncraig, Perth
    Quote Originally Posted by seangti View Post
    With the vacuum pipe unplugged (the top one) it only reaches 17psi with careful application of the throttle. Even with a stab when sitting at 14psi for example peak is always 17psi. Which makes me think I either have a leak at that pressure or the waste gate isn't holding beyond this point.
    Maybe Gav, you can help here mate. With the CC stage 1. What should it spike to an then settle at. I was thinking 20-22psi spike and 17-19psi steady tapering off as the engine eats up the boost further up in the rev range.
    Jun 2016
    Duncraig, Perth
    Quote Originally Posted by sambb View Post
    Will have a check at around the plug tonight. It's a strange one. If I can't find a break or bad connection I think a new N75 wouldn't be a bad thing. Even if it turns out not to be a problem, at least it will be good for years to come once replaced.
    I have a feeling too that my waste gate is not quite right. Seems to be in my eyes missing 2-3psi when the N75 isn't working right once heat soaked but only after switching the car off. Will not spike above 4psi even in cold dense air like this morning (raining and 17.5C).
