If you get a rubber neck filter. The clamp can shrink down onto the maf sensor.
Saves abit of money.
Hi All,
I am hoping someone could give me the part number for the MAF sensor to convert the housing from Airbox outlet connection to pipe connection to connect to a pod filter (is it the same at the Golf MKIV GTI?) for a Polo GTI?
Kai I know you've done this mod. Do you have the part # on hand?
Thanks everyone in advance.
I gave up on having a pod there tho. Heat got to it too much. Heated up the pod which then heats up the air as it travels through the pod.
